Author Topic: Google Chromecast 3 latest version  (Read 2711 times)
Offline titactoh
  • So Long As I Am Happy, Who Cares !
Re: Google Chromecast 3 latest version
« Reply #15 on: March 19, 2019, 22:49 »
Network meaning wifi.
Do you have wifi at home?
I have WiFI t home.
« Reply #16 on: March 20, 2019, 06:54 »
Ok. I lost you here.
I have not bought the Chromecast yet. I will follow your instructions when I get Chromecast from Lazarda.
Sorry for wasting your time.
Will check back again when I have bought it and set up and I would like to know if what Remote control do I use when it is set up. Until then thanks.
Trust me...you will "know what to do" when you get your hands on one :)
No worries :)
« Reply #17 on: March 20, 2019, 06:54 »
I have WiFI t home.
That's ALL you need to setup your Chromecast :)
« Reply #18 on: March 20, 2019, 08:20 »
Recommend you buy from Google store directly.
If buying from Lazada, make sure they ship you v3 not v2.
* I bought mine from Google store.
« Last Edit: March 20, 2019, 08:22 by Boxerfan88 »
Offline titactoh
« Reply #19 on: March 23, 2019, 18:05 »
Hi Desray,
I have got my Chromecast Ver3.
I want to use it on my Pioneer Plasma Tv PDP-436xga  ( No WIFI ) which has a Media Receiver with an Input HDMI.
Presently I am using a Switcher with 3 Inputs and 1 Output which goes to the Media Receiver.
!st Input is from the Starhub Set-top box. 2nd and 3rd Inputs are from my 2 DVD players.
Now I want to use the 3rd Input for my Chromecast.
I understand that the Device to direct the Chromecast is my Handphone. If I use that it will be very Hot unlike a Remote Control and I have to charge frequently especially when I am watching a Documentary/Chinese serial.  Is there anyway of using other devices other than a Hp.?
Can I use my PC instead and what connections are required ?
Any advice/guidance appreciated.
« Reply #20 on: March 23, 2019, 18:33 »
Hi Desray,
Yes you can use other devices like tablet and even PC/laptop. But you must use Chrome browser. U can go to Youtube page and then use the same technique - i.e. look out for the "Cast" icon and select your chromecast to cast the video to your TV.
In addition, you can also cast an entire webpage using Chrome browser to your TV as well. This is especially useful if you want to show images or an article on the website to your friends etc...
Offline titactoh
« Reply #21 on: March 23, 2019, 20:25 »
First with what do I need to connect my PC to the to the TV. My PC is a Dell inspiron 20" 3000 series and has a LAN socket but not sure if it is an Input or Output.
Thank you.
« Reply #22 on: March 23, 2019, 20:33 »
Thank you.
You need to have WiFi enabled on your laptop/PC. If only LAN, then cannot as for a chromecast to work, both the source (PC or laptop) must share the same WiFi network.
Offline titactoh
« Reply #23 on: May 19, 2019, 14:46 »
As I was asking on what Device do I use to download the Google Home ?
Thank you very much Desray.
A friend came with his son who was able to follow your instruction to set up this yesterday.
Now very glad I can watch Food Street n other Nature documentaries and Chinese old songs.
Just wonder if i can use the SAME  handphone to do it for another TV ( a SMART Panasonic Tv ) out in my Living Room with an additional chromemcast. Will it confuse my HP Thanks  ?
Happy Vesak Day to all !
« Reply #24 on: May 19, 2019, 18:05 »
Yes, you can setup as many Chromecast as you want - just remember to rename it with meaningful identification such as Chromecast-living-room, Chromecast-study-room etc...
Glad you finally get the Chromecast to work after almost 2 months. Better late than never.
Offline titactoh
« Reply #25 on: June 04, 2019, 18:08 »
Can anyone advise if another hp owner can use his hp to make use of the Chromecast attached to the same Tv monitor to watch Youtube so that when I am NOT USING my hp he can use his hp as remote to watch Youtube on the same monitor through the same Chromecast.
Thank you.
Offline bluepill193
« Reply #26 on: June 11, 2019, 18:45 »
yes you can. Under google home, you can set guest accounts. Based on the chrome cast ultra I use, should be same for other chrome cast models
Offline titactoh
« Reply #27 on: June 13, 2019, 17:04 »
Thank you bro. bluepill193.
Really appreciate your confirmation.
