Author Topic: Wharfdale Linton ( Cheaper Harbeth / Spendor alternative? )  (Read 8116 times)
Re: Wharfdale Linton ( Cheaper Harbeth / Spendor alternative? )
« Reply #30 on: June 27, 2019, 12:32 »
Doggie, do you have a Harbeth SHL+ to compare with the Linton?
I used to.
Offline Jagdpanzer
  • HT & Audio
« Reply #31 on: June 27, 2019, 15:58 »
How does the performance compared with Harbeth?
I used to.
« Reply #32 on: June 27, 2019, 16:05 »
I can’t say I really warmed to the sound of the SHL5+ or the C7.
It feels like they are trying to get an LS3/5 to extend beyond what they are comfortable doing.
The Radial woofer is asked to stretch to a lower register that it shouldn’t. So the bass is a little bloated and uncontrolled. That’s what I feel about both the SHL5+ and C7. The SHL5 then adds a super tweeter that I feel doesnt complement the sound.
The Linton sounds IMHO like Harbeth’s Monitor range - which I prefer over the C7/SHL5+.
The M30.2 uses the same drivers as the C7 but doesn’t try to extend the bottom end. It sounds more natural as a result. That’s what the Linton and Denton sound like.
If anything, the Linton sounds like a smaller (much smaller) M40.2. The bass still doesn’t go low. But it has a dedicated 8” woofer just to handle the low frequencies. And the midrange driver focuses on the mids.
Offline malsound
« Reply #33 on: June 27, 2019, 21:10 »
<a href="http://www.youtube.com/v/1yioqmBmQ_0&fs=1" target="_blank" class="new_win">http://www.youtube.com/v/1yioqmBmQ_0&fs=1</a>
https://youtu.be/y3RIHnK0_NE
https://youtu.be/FELbmXdS4xM
Offline malsound
« Reply #34 on: August 11, 2019, 16:20 »
<a href="http://www.youtube.com/v/1-JTBp6PQsc&fs=1" target="_blank" class="new_win">http://www.youtube.com/v/1-JTBp6PQsc&fs=1</a>
Offline malsound
« Reply #35 on: August 14, 2019, 21:06 »
<a href="http://www.youtube.com/v/zRkIBc7uAVk&fs=1" target="_blank" class="new_win">http://www.youtube.com/v/zRkIBc7uAVk&fs=1</a>
Offline malsound
Offline bolts
« Reply #37 on: August 27, 2019, 16:57 »
What is this? A “Harbeth” sound for 1/3 the price??
Really tempting.
Thiel CS 1.6 speakers. SVS SB12+ sub. Mac mini, Modded Cambridge Audio 640C V2 CDP. Lite-Audio DAC 60. Modded Hypex 180AD dual-mono amp. DH Labs Air Matrix IC, Anti-cables with WBT plugs. Acrolink P4030 PC. G & w power distributor.
« Reply #38 on: August 27, 2019, 21:21 »
It’s not a Harbeth sound.
It is a vintage sound.
And I prefer it.
Offline bolts
« Reply #39 on: August 28, 2019, 11:19 »
I tot u mention it sounded like a harbeth monitor?
Offline joamonte
  • audiophile
« Reply #40 on: August 28, 2019, 13:28 »
M30 sound like listen to master tape or CD , neutral but sometime no surprise, all music sound as correct as expected ; SHL5 more like LP , added some coloration but at the same time alway give listeners some surprise even the recording is very familiar....
I feel that Linton fall somewhere between the M30 and SHL 5, not as accurate as M30 and not as colourful as SHL5, also , I feel the mid and Low mid is a little overwhelming compare to Harbeth, also less resolution and detail I heard in my Friend place ..... but no doubt it is great value!
Offline malsound
« Reply #41 on: August 28, 2019, 14:11 »
Want to do a taste gauge test ;D
<a href="http://www.youtube.com/v/VvQWPt7Ryfw&fs=1" target="_blank" class="new_win">http://www.youtube.com/v/VvQWPt7Ryfw&fs=1</a>
« Reply #42 on: August 28, 2019, 14:59 »
I have since been listening to other speakers like the Arden and the Eatons which are also vintage inspired recreations :)
Offline malsound
Offline bolts
« Reply #44 on: August 30, 2019, 19:16 »
It looks like they have a winner on their hands.
