Author Topic: AudioQuest Storm Series Power Cables  (Read 2084 times)
Offline kimurastanley
« on: March 04, 2019, 17:03 »
Tried to search but could not find a thread about these power cables.
Any local users here to share the experience?
Plenty of rave reviews in overseas forum.
Currently auditioning hurricane HC on DAC. So far very positive impact for my system
« Last Edit: March 04, 2019, 17:12 by kimurastanley »
Offline drzero
Re: AudioQuest Storm Series Power Cables
« Reply #1 on: March 04, 2019, 21:32 »
havent tried their power cords but had great luck with their CAT7 cables and toslink
Using CAT7 Vodka on my Naim and I can only say Lan cables (strangely) do have very positive effect on Network streamer SQ, dunno how to explain, just flows better
« Reply #2 on: March 04, 2019, 22:57 »
I agree than ethernet cable does make difference. I am not using AQ ethernet but last month change the ethernet cable (from challenger) to Supra Cat8 LAN. Definitely improve the sounding.
Offline malsound
« Reply #3 on: March 05, 2019, 20:10 »
<a href="http://www.youtube.com/v/c_bJTMD5_aI&fs=1" target="_blank" class="new_win">http://www.youtube.com/v/c_bJTMD5_aI&fs=1</a>
https://youtu.be/y3RIHnK0_NE
https://youtu.be/FELbmXdS4xM
Offline tsi-dsg
« Reply #4 on: March 06, 2019, 00:19 »
Mind sharing your findings and the price?
« Reply #5 on: March 11, 2019, 19:25 »
I using 2 hurricane HC. One on Diablo 300 and one on MSB DAC (one is on loan).
Compared to a few power cables i am owning now, hurricane very Low noise. I believe the storm series will bring down the noise significantly. But once the noise very low, system will become more transparent. One worry is that it will be too bright or revealing. When I home trial thunder which is the entry level, I hear some digital smears and edgy highs on my system, but still not too bad.
But when I change to hurricane, I don’t hear the edgy highs. Smoother sounding than thunder, while maintaining the other sounding character I hear on thunder but better.
For me, I think the most obvious change I listened is more dynamic, details, wider stage and vocal pushed slightly forward.
Offline tsi-dsg
« Reply #6 on: March 11, 2019, 19:37 »
Thanks for the info.
So we both are using the same amp, I believe connecting to the amp has more impact than dac?
« Reply #7 on: March 11, 2019, 20:39 »
For me, power cable on my DAC has more impact than amp.
Next up thinking to try their Niagara power conditioner.
« Reply #8 on: March 11, 2019, 20:41 »
I read Vodka delivers 90% performance of Diamond  ;D ;D
Offline tsi-dsg
« Reply #9 on: March 11, 2019, 21:53 »
For me, amp has more impact than dac, the Niagara looks interesting based on their design, the 7000 had a very solid chassis,same price range as Shunyata Triton3, the 5000 pricing will be the sweet spot in many systems,maybe we can do an AB with your Hurricane n mine.
Offline malsound
« Reply #10 on: May 23, 2019, 06:58 »
<a href="http://www.youtube.com/v/1zW3Q7RXgVg&fs=1" target="_blank" class="new_win">http://www.youtube.com/v/1zW3Q7RXgVg&fs=1</a>
Offline Rachael
« Reply #11 on: July 17, 2019, 01:35 »
Hi, may I ask details of improvements u noticed after using Supra Cat 8 LAN?
Thank you in advance for your kind advices.
