Author Topic: Official Anthem MRX 720/1120 thread (II)  (Read 9012 times)
Re: Official Anthem MRX 720/1120 thread (II)
« Reply #45 on: May 04, 2019, 11:25 »
It appears that the MacOS version of the ARC Genesis has some teething compatibility issues here. So there are some bugs that need to be addressed by Anthem for Mac users. For Windows users, I'm happy to report that it worked right out of the box with no issue.
Offline john_125
« Reply #46 on: May 04, 2019, 13:20 »
Can't wait to try it out. Uncalibrated amp already sounds very good to me :)
« Reply #47 on: May 04, 2019, 13:36 »
This is a whole "new" level of sound altogether. I will provide some user experience here later today or tmr.
<a href="http://www.youtube.com/v/P2-VDJcAOog&fs=1" target="_blank" class="new_win">http://www.youtube.com/v/P2-VDJcAOog&fs=1</a>
« Last Edit: May 04, 2019, 16:11 by desray »
« Reply #48 on: May 04, 2019, 15:31 »
Here are some screencaps of the new ARC Genesis interface. Compared to the previous version (ARC 2), the interface is much more cleaner and exude a more "pro" look and feel. As you can see, Anthem is trying to emulate D&M setup user interface depicting the diagram to the right to "prompt" the user to move from one calibration position to the next. The design interface is touch-friendly meaning you can use your fat finger or a stylus to move around with ease. No more squinting of eyes to struggle and see the wordings.
The most interesting section of this new version of ARC is the ability to adjust Max EQ frequency for each individual speaker group (e.g. Dolby Atmos height speakers or just the Surround channels) from 200Hz all the way up to 5kHz or higher (though not advisable as too high, the frequency range becomes more "audible" - localized). You can now have more granular control over the Room Gain by only affecting a certain range of frequency instead of the entire range. There is a "new" feature called, Deep Bass Boost which allows one to build a unique "house curve" by adding a few db to the lower range and once again, you can choose to set the epicenter of the frequency range for the Deep Bass Boost to take effect. This is especially useful if you want that ULF kick below human audible range starting from  80Hz and below with adjustable gain up to +6db.
There is also another "new" feature called, Tilt level which I still can't figure out what it does...probably affect one end of the spectrum with an equal and opposite gain/attenuation at the other end. Not sure what it is for...Need to explore more.
For the very first time, individual speaker has its very own high-frequency roll-off to complement the LFE crossover (bass management). What Anthem does is it will take each speaker natural low frequency roll-off and the subwoofer(s) high frequency roll-off to determine the optimal HL and LF roll-off from speakers to the subwoofers and this is "crown jewel" of ARC that differentiate itself from the more traditional Room EQ found in Audyssey, AccuEQ Phase, YPAO and MCACC...
« Last Edit: May 04, 2019, 15:59 by desray »
« Reply #49 on: May 12, 2019, 15:44 »
New version of ARC Genesis released by Anthem on 11 May 19.
Download link: https://www.anthemarc.com/downloads/index.php
Changelog:
Version 1.0.1.8867
- Added a new shortcut in the start menu that forces ARC Genesis to use the angle library rather than the GPU's
- changes to preferences are commited on immediate exit
- loading indicator is now shown with device image image in middle on screen
- 'button' User-Interface (UI) element can now support two lines of text
- removed duplicate completion text for reset eq screen
- added a browse for calibration file to mic selection screen
- fixed an issue where calibration files that included 'Anthem', 'Paradigm' or 'MartinLogan' in the filename were not supported
- fixed an issue where some code paths did not properly handle unicode text/paths
- added a web download link for manual calibration file download
- fixed the issue where some users were unable to download calibration files, or would get the "critical audio problem" during the initialization phase of measurements
- filtered duplicate devices in the supported devices screen
- paired (left/right) MartinLogan Masterpiece series speakers now have a unique curve color for the left/right speaker
- fixed packaging of mac release where license.txt and firmware update files were not being copied to the application bundle
« Reply #50 on: May 12, 2019, 16:03 »
After playing with ARC Genesis for an extensive period of time (for 1 week) and I must say that Anthem ARC is even more refined than ever before. The new features in ARC Genesis allow users with more flexibility in tweaking the sound to the heart's content. I have to say that it has now reached the level refinement of Dirac Live. The only missing feature missing from ARC Genesis or ARC 2 is the time domain that affects the phase which can easily be fine tuned by other means - playing a 80 Hz sine wave (or the crossover value set by ARC) and play around with the phase control and distance measurement.
I am happy to say that my Anthem MRX 720 has sounded even better after calibrating with ARC Genesis. If you have the budget and wants to try some other Room EQ algorithm other than the Audyssey, Anthem MRX or the AVM60 Pre-pro should be placed on top of your short-list.
Well done Anthem!
« Reply #51 on: May 12, 2019, 16:04 »
I’m impressed. Really looks good.
« Reply #52 on: May 12, 2019, 16:32 »
Will pay you a visit soon to hear your StormAudio - likely next weekend Sun late morning.
« Reply #53 on: May 12, 2019, 17:17 »
Arrange offline :)
« Reply #54 on: May 12, 2019, 18:02 »
Arrange offline :)
Yes pl.
« Reply #55 on: May 12, 2019, 18:26 »
Very nice !
I have the same options on the lyngdorf to use “natural roll off”, for each speakers. Quite interesting, a lot of the folks in Europe are using this feature, bass is still being defined on the aspect of what gets sent to bass management plus the speakers will receive the full range signal and be allowed to roll off naturally according to its characteristics... the Eq programme also phase aligns the speakers with subs, this is the part where RP does a good job, check out that one on the ARC
This feature is commonly found on Denon or Onkyo as LFE + Mains, double bass...
One noted problem with this is bloated bass, but I believe the EQ programme does something different to make it sound good and less bloated,  check that as well, I haven’t tried this feature
I subscribed to the idea that subwoofers are better off handling frequency below 100hz, leave the headroom for the mains for it to cruise and be relieved of any bass duties down till its roll off frequency
There is also a lot of capable full range speakers out there that can do a good job down 20hz ...
« Reply #56 on: May 24, 2019, 07:30 »
Anthem is really going forward with their new ARC Genesis...here's the beta release. Mostly fixes.
Full changelog for this version 1.1.0.8908:
- added support for many older Paradigm Subwoofers (8872): DSP-3100, DSP-3200, DSP-3400, Signature SUB 25, Monitor SUB 10, Monitor SUB 12, Monitor SUB 8, SE Sub, SUB 1, SUB 2, SUB 12, SUB 15, UltraCube 10, UltraCube 12, X-300
- MacOS: fixed an issue where microphones with serial number less than roughly 308000 would incorrectly measure at the maximum microphone volume (1410)
- fixed issue where ARC Genesis would measure 3 dB lower than ARC2 (1410)
- fixed an issue where ARC Genesis would not release exclusive control when leaving quick measure (1376)
- fixed an issue where ARC would claim to have downloaded the microphone calibration file, but it actually failed. (1405)
- MacOS: minor correctness fix in the face of errors when enumerating usb devices (650 and 800)
- MacOS: improved robustness of USB device support (650 and 800)
- fixed clicking cancel in the open file screen causes the app to crash (1392)
- fixed Tilt Start Frequency displays incorrect information in the PDF report (1418)
- fixed an app crash that occured if you clicked 'cancel' after getting communication errors during the connecting screen (1424)
- fixed issue where app could crash after audio errors during measurement and the user went back to the home screen (1331)
- fixed an issue where scrollbars where not always showing in dropdowns (1411)
- fixed an issue where the 'Resume' was displayed instead of 'Start' in the measurement screen (1370)
- fixed typo correction "Currected" to "Corrected" (1409)
- added a loading indicator for quick measure initialization & removed visibility of unused graph title (1383)
- increased visibility of no microphone message
- info popup centered below info icon
- open file screen clears previous device image (1393)
- back button from mic selection screen returns to configure screen (1372)
- red error text fix for measurement screen
- fixed possible clipping in MRX x10/x20 when ARC is turned on (content dependent) (1415)
Download link: https://www.anthemarc.com/downloads/beta.php
 :D
« Reply #57 on: June 29, 2019, 11:36 »
New update to the ARC Genesis s/w released! Here are the detailed changelogs:
Version 1.1.0.9006
- added audio capture entitlement when signing macos version to prevent crash on macos 10.14.5
- request audio capture permission when first entering the microphone selection screen
- Added Spanish translations
- Added official Anthem MDX-8 and MDX-16 support
- fixed issue where the demo mode was using duplicate curves for position 1 and position 2 (1169)
- improved handling of changes to the speaker / measurement mapping (1455)
- prevent -0.0 from being selecte as a test tone level during the auto level sequence (1427)
- further improvements to always release exclusive control as soon as possible (1376)
- further refinements to calibration file download
- fixed Defiance X10/X12/X15 don't work over USB connections (1397)
- fixed issue where windows versions incorrectly required the user to have the vs2012 redistributable installed (1432)
- fixed auto phase adjust sweep output for STR Integrated R and L subs (1406)
- improved handling for when phase adjust needs arc upload (1333)
- decreased phase adjust sweep volume  (1334)
- added cancel button to the auto phase screen (1439)
- improved audio error handling on windows
- improved handling of usb errors (mac and windows)
- added automatic check for new ARC Genesis updates, prompts with option to open browser and download manually
- added option to enroll for beta releases (in preferences screen)
- increased STR profile name to allow up to 9 characters (maximum currently supported by STR IP commands)
- added notarization for mac OS builds to support mac os 10.14.5 or later
- fixed Defiance X10/X12/X15 don't work (1397)
- fixed an issue where ARC would claim to have downloaded the microphone calibration file, but it actully failed. (1405)
- fixed an app crash that occured if you clicked 'cancel' after getting communication errors durring the connecting screen (1424)
- fixed issue where app could crash after audio errors during measurment and the user went back to the home screen (1331)
- added a loading indicator for quick measure initialization & removed visiblitly of unused graph title (1383)
Download here: https://www.anthemarc.com/downloads/index.php
« Reply #58 on: July 06, 2019, 12:11 »
There is a bug in this latest stable release and this was acknowledged by the Anthem Support Team. So a PSA for all Anthem users to refrain from over-writing the previous stable release. I have been advised to use the Beta release instead (sport the same version number in their website but it is different according to the Tech support).
« Reply #59 on: July 06, 2019, 12:13 »
My Anthem MRX 720/1120 has found a “new owner” and as such, I will not be able to contribute actively to this thread anymore. For those who are using Anthem, I urge other owner to continue to use this thread for updates in terms of firmware or any issue(s) etc.
« Last Edit: July 06, 2019, 14:39 by desray »
