Author Topic: New Launch and updates - Isolation Transformer (6 Ways) (Acoustic Synergy)  (Read 64 times)
Offline jng2
Thank you bros and sisters for the past and continuous support and kindly allow us to introduce our new product in the Accessories collection
The isolation transformer is designed to reduce the incoming AC main noise to your equipment.
It comprises of a transformer with symmetrical windings, which is used to decouple two circuits. It allows an AC signal or power to be taken from one device and fed into another without electrically connecting the two circuits. This helps to filter out AC input noise by EMI and RFI to the equipments. It also blocks the interference caused by ground loops issues.
The unit also comprises of a power filtering device (Made in Switzerland) to further clean up any noise while providing extremely low-impedance and high-current conditioning for power-demanding high-end audio and visual devices.
It has 3 pairs of Hubbell US receptacles (Made in USA) with total of 6 ways power outputs where
- 2 pairs in red colour where the power supply has passed through the isolation transformer with power filtering (for source , preamp, integrated amp, avr  etc)
- 1 pair in grey direct from power input (for power amp, integrated amp or avr etc)
The internal wiring is now upgraded to DOUBLE run of 14 AWG 7N Pure Silver with Teflon insulation or DOUBLE run of 12 AWG 6N PCOCC Pure Copper internal wiring ! This has greatly enhance on overall performance!
It gives much lower noise floor and it helps to bring out the micro details and fluidity that you have missed previously. Overall sonic reproduction is much more refined and good clarity. The bass is tighter and faster after undergoing cable tweak.
Features:
1000 VA (13 Amps) power output for 2 pairs of Hubbell US receptacles in red colour
1 pair of Hubbell US receptacles in grey direct from power input
AC Power Filter
Extra thick gold-plated outlet and IEC male
DOUBLE run of 14 AWG 7N Pure Silver or DOUBLE run of 12 AWG 6N PCOCC Pure Copper internal wiring
Thick silver face plate aluminium-alloy chassis
Digital front led voltage indicator
Soft start to protect equipment from turn-on surges
Power surge protection
S$1250 /each for DOUBLE run of 14 AWG 7N Pure Silver internal wiring
S$850 / each for DOUBLE run of 12 AWG 6N PCOCC Pure Copper internal wiring
Kindly refer to website link in the signature below if you need more information.
One-stop for all your cable and accessories need
We have Powercords, Stereo Interconnects and Headphone Cables, Portable 3.5mm-3.5mm Jack Interconnects, Y cables, Subwoofer Interconnects, Speaker cables and jumpers, HDMI cables, Isolation Transformer, Ground Isolator, Power Distributor, In-Line Filter, Spike plates, RCA caps, Bluray lens cleaner etc.
My contact is 91182849. Thankyou
One-stop online shop for cables and accessories to meet your need :
http://acousticsynergy.weebly.com/index.html
