Author Topic: New launch - "Silver Bunny" Powercord (Acoustic Synergy)  (Read 55 times)
Offline jng2
Thank you bros and sisters for the past and continuous support. We always continue to provide better performance product by sourcing on better cables or by modifying on existing configuration. Kindly allow us to introduce our new product in the Powercord collection
Silver Bunny cable is made of multi stranded 20 AWG 6N pure silver as signal conductors with teflon as dielectric and is shielded with outer layer pure silver EMI/RFI canceling braid.The exterior of the cable is covered with teflon insulation.
Made in Germany.
It is terminated with very good quality and well plated plugs. The core material is made up of 99.99% pure OFC copper. All the Earth, Neutral and Live pins are Rhodium plated. Both the US and IEC plugs are shielded with aluminium casing.
It needs minimum of 50 hours to run in for optimal performance.
The powercord has excellent shielding configuration that results in very low noise floor. When noise is eliminated, the background is much quieter , hence it will give better details.
It shares similar in sonic characteristics with Silver Bunny interconnect in its ability to give great clarity, silky smooth and liquid mid-range. The high is extended and the bass is well controlled!
It comes in 2 versions - Single Run or Double Run Configurations
Kindly note that other option is also available
- MK audiophile grade UK plug / US plug
- Figure 8 plug / IEC/ 20A IEC
Pricing (In Singapore dollars not inclusive of registered postage)
"Silver Bunny" Power Cable in Single Run Configuration
1. Powercord (1m) with male connector plug, iec plug with aluminium casing ($230)
2. Powercord (2m) with male connector plug, iec plug with aluminium casing ($380)
"Silver Bunny" Power Cable in Double Run Configuration
1. Powercord (1m) with male connector plug, iec plug with aluminium casing ($380)
2. Powercord (2m) with male connector plug, iec plug with aluminium casing ($680)
One-stop for all your cable and accessories need
We have Powercords, Stereo Interconnects and Headphone Cables, Portable 3.5mm-3.5mm Jack Interconnects, Y cables, Subwoofer Interconnects, Speaker cables and jumpers, HDMI cables, Isolation Transformer, Audio Enhancer, Ground Isolator, Power Distributor, In-Line Filter, Spike plates, RCA caps, Bluray lens cleaner etc.
My contact is 91182849. Thankyou
One-stop online shop for cables and accessories to meet your need :
http://acousticsynergy.weebly.com/index.html
