Author Topic: Marble slab under speaker  (Read 995 times)
Offline ryanchong
« on: February 09, 2019, 09:40 »
Anyone can explain why my Harbeth HL 5 +speaker turns alive after I put two heavy duty marble slab under it supported by cheap footers? What's the scientific explanation?
BadEnglish
Re: Marble slab under speaker
« Reply #1 on: February 09, 2019, 10:37 »
Vibration
Offline deepakvali
  • Trade Count: (+6)
  • La Resistance !
« Reply #2 on: February 09, 2019, 10:58 »
If you are on stands, put the stands above it, another characteristic. I personally don’t like the sound character with marble/granite but it’s personal.
Dynaudio Focus 110 - looking for new home and also other budget cables ;)
« Reply #3 on: February 12, 2019, 14:14 »
Anyone can explain... What's the scientific explanation?
In brief...
<a href="http://www.youtube.com/v/8Pd8UK6SZ_s&fs=1" target="_blank" class="new_win">http://www.youtube.com/v/8Pd8UK6SZ_s&fs=1</a>
Offline ryanchong
« Reply #4 on: February 13, 2019, 07:48 »
thanks Andrew, I saw his other videos too but most of the time I don't quite understand what's he is driving at?
« Reply #5 on: February 19, 2019, 17:21 »
Bottom line is that any physical/vibration-related changes you make to your system, especially speakers, will have a sonic impact. Marble-slab on top of your HL5+ will probably have an even bigger sonic impact (good or bad, depending on your point of view) ;D
