Author Topic: Auralic Aries G1  (Read 1581 times)
Offline wvs007
Auralic Aries G1
« on: February 06, 2019, 09:57 »
I am looking at adding an Auralic Aries G1 to my system. I have a few Bluesound streamers which are quite good but not hi-end sound..IMHO.
Does anybody have experience with Auralic products...or equivalent components around $3k budget?
Thanks, and Gong Ci Fa Cai to all!
« Last Edit: February 06, 2019, 10:14 by wvs007 »
HiFi setup : Gato Audio DIA-400S / Usher BE-718 / Oppo BPD-105D / Apple MacMini / Telos Black Reference / Isotek Premier / Auralic Aries Streamer
Mini HiFi : Peachtree Audio Nova 150 / Bluesound Power Node 2 / Bluesound Node 2 / Arcam IRDac / Dynaudio Focus 110 / Peachtree Audio D4 / Emotiva Basx S8 sub / Wyred4Sound MintAmp / Emotiva Stealth PA-1 / Tellurium Black
Spare room : Marantz MCR-611 / Peachtree Audio MusicBox / MartinLogan Motion 4
Offline Jsen
  • Diamonds are NOT Forever while Silence is Golden
Re: Auralic Aries G1
« Reply #1 on: February 06, 2019, 11:15 »
Perhaps can listen to Lumin's streamer.  Good value at that price point. Currenly using U1 mini which is very revealing. Beware of your pairing of dac though. Cheers.
« Last Edit: February 06, 2019, 12:21 by Jsen »
Dynamics are the essence of how well you can feel the emotions and sentiments from the maestros and what they are trying to propose.
Offline tsi-dsg
« Reply #2 on: February 06, 2019, 11:23 »
I highly recommend Lumin too,for that price point, u can look at D2, did AB with Blue Node , improvements day and night.
Stereo: Gryphon Diablo 300, Magico A3 , Lumin D2 , LH Labs The Source SSD w/KECES lps, LH Lab Vidac Signature Dac
HT 5.2.2 : Denon X3400H,Magico A3 HT Bypass(front), Elac atmos(front),SVS SB2000(sub), Kef 3005HT(surround),MA CC300(Center)
Accessories:Synergistic Research Powercell 8se UEF,Synergistic Research Galileo cord,Kubala Sosna Elation Cord,,Albedo USB,Ansuz Aluminum XLR ,Solidsteel rack, Taoc Tit33S, AET footers
Source: Nvidia Shield TV, NuBox android
Offline MusicEar
« Reply #3 on: February 07, 2019, 09:31 »
I used Auralic Aries Mini for many years now and recently upgraded to Aries G1. I must said in term of SQ, the Aries G1 is a big improvement. The thing I like about G1 is the big high res display that shows the album art, a study built chassis. There are factors such as built-in linear power supply, XMOS femto clock for the lowest jitter via USB output. In the software side, you can use SMB to access your NAS music library without resort to DLNA and MimicServer. I use it together with Holo Spring DAC and I highly recommend when you consider a separate streaming transport and DAC.
« Last Edit: February 07, 2019, 09:37 by MusicEar »
Holo Spring NOS R2R level 2 DAC | Holo Audio Titanis USB Regen | Auralic Aries G1 | Seagate PersonalCloud 4TB NAS | I.AMP.D linear power supply for NAS | VTL 2.5i pre & VTL MB-125 monoblock tube power amps | Dynaudio Contour 1.8mk2 floorstanding speakers | Taralabs Reference Gen mk2 audio interconnects | Alpha Goertz MI-3 speakers cables & Chord Silverplus USB cable | W-Audio power distributor terminated with WattGate plugs | Lightning DS and Roon Core
Offline kkylp
« Reply #4 on: February 07, 2019, 10:58 »
Hi bro,
May i know where can i purchase the Auralic Aries G1? Understand there is no local dealer in Sg.
Offline kelvinsin
« Reply #5 on: February 07, 2019, 12:08 »
I used auralic aries mini and now using altair, i must said its a very good streamer with consistent firmware upgrade.
HT: Pioneer LX-89, Emotiva XPA-5, Dali Ikon 7 MK2, Tannoy Revolution DC6Tse, Tannoy Revolution Signature DC6LCR, Deft Tech Pro Monitor 800,Dali Lektor 2,HSU ULS15 MK2, Velodyne SPL800i, Zidoo x9s,Philips S9700, Oppo 203, LG OLED65C8P
Offline MusicEar
« Reply #6 on: February 07, 2019, 13:19 »
Hi bro,
I got directly from Auralic US, shipping is free. I brought it for USD2199 last year before the price increased. This worked out around SGD3000.
https://us.auralic.com/products/aries-g1
Offline kkylp
« Reply #7 on: February 07, 2019, 14:18 »
Thanks for the info. I am also deliberating on the Lumin D2 but Lumin doesn't have built-in WiFi capability and my room doesn't have a router. I reckon the only option would be the Aries G1 to stream audio files from the room next door. Wondering if there is a noticeable difference in SQ between WiFi streaming and Ethernet cable on the Aries G1. Has anyone A/B between the Aries G1 and the Lumin D2 ?
Offline tsi-dsg
« Reply #8 on: February 07, 2019, 19:40 »
I will guess ethernet cable will be the best bet with stronger and stable signal, u can use google mesh(recommended) or use an extender in your room, then use the ethernet port, which I’m using now.
Offline kkylp
« Reply #9 on: February 07, 2019, 22:39 »
Thanks bro. Will consult Dr. Google for more info and consider the 2 options.
Offline kelvinsin
« Reply #10 on: February 08, 2019, 01:39 »
As oer auralic designer he strongly suggest to use 5ghz wifi than LAN for the best performance. For details can refer to auralic forum or their qq group (if you understand chinese)
Offline kkylp
« Reply #11 on: February 08, 2019, 11:11 »
Hi bro,
Does the Aries G1 comes in local voltage? Do i need to specifically indicate this at point of purchase in the note box?
Offline MusicEar
« Reply #12 on: February 08, 2019, 14:18 »
Hi bro,
Yes of course. Please do that and also state from Singapore. Please contact Xuanqian Wang CEO of Auralic on your queries and visit his forum at
https://community.auralic.com
Review: https://youtu.be/juKqFso3nTw
« Last Edit: February 08, 2019, 14:41 by MusicEar »
Offline kkylp
« Reply #13 on: February 08, 2019, 15:16 »
Noted and many thanks for the valuable info. Cheers !
Offline wvs007
« Reply #14 on: February 12, 2019, 15:18 »
This UK shop is also doing international delivering :
https://www.audioemotion.co.uk/streamers--music-servers-586-c.asp
