Author Topic: Attn Tascam Da3000 Owners - Assistance needed  (Read 1506 times)
Online Chowbotak
  • Trade Count: (+7)
« on: February 04, 2019, 07:46 »
I am using the Tascam (firmware 2.02) to record vinyls and this is what happened.
Recorded one song in 4 different formats. Transferred to my NAS thru my laptop. Can only play the first song (DSD 2.8) thru my Naim NDX. So I tot, maybe the DA-3000 does not allow the file format to be changed during a recording session so next round I recorded a number of tracks in the same format, WAV 24/192. The only settings I changed was the input volume. Cunt play any of the files. Next day, I format my sd card using the Tascam and recorded a few tracks, all same format. Same problem.
Am using an old HP Elite laptop, Win 7 I think. I have written to Tascam. What do u think could be the problem? Thanks!
I
Online Chowbotak
  • Trade Count: (+7)
Re: Attn Tascam Da3000 Owners - Assistance needed
« Reply #1 on: February 04, 2019, 16:50 »
Settings:
Media selection : SD, Clock Master: Int, Ref level: - 16db, Cascade: Off, File: WAV 24, Sample: 192khz, Channel: Stereo, Name: Date, Input Selection: Unbal, Input vol: - 3db, SRC: Off, ADDA Direct: Off, In monitor: On, Sync Recording: Off, Auto Track: Off, Pause Mode : New track, Play mode: Continue, Repeat: Off, Track Gap: Normal
;D
Online Chowbotak
  • Trade Count: (+7)
« Reply #2 on: February 04, 2019, 18:31 »
I tried again, this time recorded two tracks at 24/96. Plays fine! So am wondering, is the issue wirh my Naim NDX? ???
Seems like it cunt play DSD 5.6 and 24/192
Update: Checked. The Naim is supposed to be able to play 24/192. So the problem must be my old laptop? Or the cheapo card reader?
« Last Edit: February 04, 2019, 18:40 by Chowbotak »
BadEnglish
« Reply #3 on: February 04, 2019, 18:39 »
Your best friend is user manual.
According to website
Your player support
WAV (up to 24bit/192kHz)
AIFF (up to 24bit/192kHz)
FLAC (up to 24bit/192kHz)
DSD (single rate DSF64 & DFF64 only)
ALAC (up to 24bit/96kHz)
WMA (up to 16bit/48kHz) must be WMA 9.2
Ogg Vorbis (up to 16bit/48kHz)
M4a (CBR and VBR up to 320kbit/s)
MP3 (CBR and VBR up to 320kbit/s)
Playlists (M3U, PLS)
What format of 24-192 is the question.
Online Chowbotak
  • Trade Count: (+7)
« Reply #4 on: February 04, 2019, 23:06 »
Quote from: BadEnglish link=topic=282090.msg1297750#msg1297750 date=1549. 276795
Your player support
Thank you, my fellow Prof cscbb fan bro! ;D
I recorded Wav 24/192, transferred file to my NAS, the NDX cunt play. So prof would conclude that must be my computer mediocre, or my brain mediocre bah  :'(
BadEnglish
« Reply #5 on: February 04, 2019, 23:28 »
Sounded like your DLNA setting rather than your medicore player ;D
Check your DLNA
Online Chowbotak
  • Trade Count: (+7)
« Reply #6 on: February 05, 2019, 10:37 »
Hmm insufficient bandwidth? How to address that? Shucks, prof will now say I'm below mediocre
BadEnglish
« Reply #7 on: February 05, 2019, 11:16 »
Your 24-192 WAV file is read from NAS or streamed from your notebook?
Is only 24-192 WAV you recorded not playing ?
What is your NAS ?
Online Chowbotak
  • Trade Count: (+7)
« Reply #8 on: February 05, 2019, 12:15 »
Maybe my NDX firmware not up to date? According to old review it did mot support 24/192 at that time. So far 24/96 and DSF 2.6 can play. My NAS is Synology DS218 play
Sent from my G3226 using Tapatalk
« Last Edit: February 05, 2019, 12:20 by Chowbotak »
BadEnglish
« Reply #9 on: February 05, 2019, 13:27 »
It's very likely that you are having the old version of firmware on NDX.
I doubt it's NAS but disable Enable audio transcoding of DMA Compatibility in Media Server of your NAS if it's enabled.
Online Chowbotak
  • Trade Count: (+7)
« Reply #10 on: February 05, 2019, 18:11 »
Seems like my firmware version shd be able to play 24/192
Online Chowbotak
  • Trade Count: (+7)
« Reply #11 on: February 05, 2019, 18:30 »
BadEnglish
« Reply #12 on: February 05, 2019, 18:37 »
Ah getting more interesting.
Can you confirm other 24-192 WAV also can't play ?
Online Chowbotak
  • Trade Count: (+7)
« Reply #13 on: February 05, 2019, 19:06 »
Yes bro, recorded 4 tracks at 24/192. All cunt play. Aiya maybe prof can help but where is he ah ;D
« Reply #14 on: February 05, 2019, 19:22 »
Bro,
May I suggest you install Audacity software, and load the recorded 24/192 WAV file. It’s easy to check if the WAV file has music signal or is just silence.
This should be able to help you confirm if it’s a recorder problem or player problem.
« Last Edit: February 05, 2019, 19:24 by Boxerfan88 »
