Author Topic: My 7.2.6 HT construction journey  (Read 1697 times)
Offline lampsy86
Re: My 7.2.6 HT construction journey
« Reply #15 on: February 02, 2019, 00:34 »
I've built subs with many drivers: Acoustics Elegance, Rythmik, Dayton, old SVS, Wavecor, SB Acoustics, CSS, TC Sounds; of various models. How, interested? ;D
Ohhhh Rythmik.........tempting  :D
Sent from my ONEPLUS A5010 using Tapatalk
Offline wechnivag
« Reply #16 on: February 02, 2019, 10:24 »
Nice, full RSL speakers and subs! Have you heard them before?
Are you getting some kind of bulk shipping? Think you have one pallet full with the subs, mains, surround and atmos!
Offline lampsy86
« Reply #17 on: February 02, 2019, 11:41 »
Already have 3 of the CG23S, I love them.
Love their size, their performance for their size & $ ! Great value ! Solid built. Not bright sounding nor muffled & boxy either.
As for the speedwoofer & in-ceiling speakers I'm going with blind faith on the brand & owner reviews.
They have a new CG5 line, but unfortunately it is quite a bit more expensive than the CG3 & quite a bit bigger in dimensions as well. They also have a bigger subwoofer in the pipeline coming soon, I believe 12inch driver to complement the CG5 line. There is also a rumour they might be introducing a tower speaker to match the new CG5 bookshelf & centre.
Their shipping is quite reasonable, they use FedEx. Will be getting the 6 C34E in ceiling speakers first, then later will be shipping in the additional 4 CG23s I need plus the 2 subs.
No space to put all the boxes, crashing at wife's parents place for the time being. So unfortunately have to split the shipping. My existing AV gears are already all boxed up & taking up space at brother's place, can't add more boxes, he will kill me
Need to see if the split shipping end up costing significantly more, if it does, then will just wait till Reno is 70% done & then get them shipped all together.
« Reply #18 on: February 02, 2019, 13:17 »
Bro, I’m using C34E in TOP 6 atmos. If you keen to have a listen instead of going blind can pm me.
Offline lampsy86
« Reply #19 on: February 02, 2019, 13:19 »
That would be great, maybe will PM you for a post CNY demo visit to your convenience. Thank you !!!
Offline lampsy86
« Reply #20 on: February 02, 2019, 14:34 »
Btw.....do you have them in any enclosure ? What is the crossover setting for them ?
« Reply #21 on: February 02, 2019, 15:35 »
No enclosure. Just stuck behind false ceiling. However, get an enclosure if you can. Also reduce sound bouncing off internally entire ceiling.
Offline lampsy86
« Reply #22 on: February 02, 2019, 15:38 »
Noted. You have them crossed over at ?
« Reply #23 on: February 02, 2019, 17:45 »
They dont go low, min 80hz or higher. Depends on your preference.
Offline lampsy86
« Reply #24 on: February 02, 2019, 18:01 »
Ah ok. 80hz will do me fine.
Offline jeffong
  • You'll Never Walk Alone
« Reply #25 on: February 08, 2019, 07:41 »
Since you are doing your reno and might have a future inclination towards a projector, would recommend that you lay in your HDMI, Ethernet and Power cables to the back of your living room during your reno period so that you have a painless upgrade option in the future.  You can also cater for power point at the front area in the false ceiling to support a motorized screen option in future.  Just my two cents.
HDR Rulez - UHD-K8500 | Oppo UDP-203 | Roku 4 | Nvidia Shield
Stewart Firehawk 92" | LG 65E6T | Panny 65VT30 | Sony 40NX720 | Panny AE7000
Denon 7200WA | Denon 4520 | Denon 2309 | SVS PC-12+ | JL E110
UHD BD Titles : More than 20
Offline lampsy86
« Reply #26 on: February 08, 2019, 23:13 »
Thank you. :)
« Reply #27 on: February 08, 2019, 23:24 »
You will always run out of powerpoints too ???
Offline lampsy86
« Reply #28 on: February 09, 2019, 20:31 »
Sorry, but I don't get your question...was it for me ?
« Reply #29 on: February 09, 2019, 21:01 »
It’s a statement not a question...heed my warning  :)  applies to everyone.
« Last Edit: February 09, 2019, 21:10 by wizardofoz »
