Author Topic: help pc problem  (Read 1398 times)
Offline qflyer
Re: help pc problem
« Reply #15 on: February 01, 2019, 21:49 »
There is nothing important or private files in the hdd. The deleted files can easily restore from the recycle bin. I will replace the battery and do a full installation.
Any good and free anti virus software?
« Last Edit: February 01, 2019, 22:01 by qflyer »
Re: help pc problem
« Reply #16 on: February 02, 2019, 07:26 »
I’m using Avast as primary anti-virus.
Plus occasional manual scans using Malwarebytes to cross check.
Offline qflyer
Re: help pc problem
« Reply #17 on: February 02, 2019, 08:05 »
ha no more bios and files deletion problems, all gone. the root cause is the stupid stupid stupid keyboard.
"£$£$^£$%&£&$"^£££$£**9
thanks for all the helps.
