Author Topic: help pc problem  (Read 2040 times)
Offline qflyer
help pc problem
« on: January 31, 2019, 16:33 »
my pc running win 8.1 keeps booting into bios, whats wrong? and how to stop it?
Re: help pc problem
« Reply #1 on: January 31, 2019, 16:53 »
I’m assuming it doesn’t even reach HDD boot.
If PC is very old, check CMOS battery on motherboard.
Check and reseat DRAM.
Reset BIOS to default config may help.
Offline qflyer
Re: help pc problem
« Reply #2 on: January 31, 2019, 17:13 »
yes old pc but how do i know the battery is low? a simple replace battery will work?
thanks.
Offline pcking
Re: help pc problem
« Reply #3 on: January 31, 2019, 17:20 »
PC BIOS battery is commonly just a CR2032 battery.
If the message says something like Checksum error or Date Time error.
Offline alamakazam
Re: help pc problem
« Reply #4 on: January 31, 2019, 20:04 »
reboot to bios means what? just restart and restart ? did it manage to boot to windows?
if battery low... it will probably hang there with a fault...  press f1 to continue
it keep on rebooting, maybe something else... power supply? motherboard
Offline qflyer
Re: help pc problem
« Reply #5 on: January 31, 2019, 20:29 »
Strange no such message.
It will boot into bios and I will exit the bios without making changes and into windows. Funny huh
I have tried hard reboot and it will still boot into bios again.
Re: help pc problem
« Reply #6 on: January 31, 2019, 21:09 »
Strange no such message.It will boot into bios and I will exit the bios without making changes and into windows. Funny huh
Is the scenario like this?
1. PC is powered OFF
2. PC switched ON
3. PC hoes through POST then goes into BIOS screen.
4. You don’t make any BIOS change, save and exit BIOS.
5. PC continues booting into Windows.
6. Windows works normally.
7. You can use Windows without problems for hours.
8. You shutdown Windows.
Going back to step 1, the same steps repeat?
If yes, very very good chance your motherboard battery is dead. Changing the battery would be a good starting point. That battery is cheap.
Reason: after you shutdown/OFF PC, and if the battery is dead, your BIOS configuration setting will be lost once the capacitor discharge (maybe 5mins). When you power up, the BIOS think it is a new unconfigured motherboard, so bring you to BIOS screen.
Offline qflyer
Re: help pc problem
« Reply #7 on: January 31, 2019, 21:51 »
2. PC switched ON
Yes. 2moro better buy a battery.
Offline qflyer
Re: help pc problem
« Reply #8 on: February 01, 2019, 19:20 »
Yet to replace the battery. There’s another problem now. Whenever I open a folder it will automatically delete the files.
@#&**()&&(£#@ bloodyyyyyyyyy.
Offline alamakazam
Re: help pc problem
« Reply #9 on: February 01, 2019, 19:30 »
i tell u... your delete button got problem is it
del button goes to bios
del can delete files
maybe
Offline qflyer
Re: help pc problem
« Reply #10 on: February 01, 2019, 19:42 »
Ok I will stick my spare keyboard into the pc later.
Offline alamakazam
Re: help pc problem
« Reply #11 on: February 01, 2019, 20:01 »
also cmos battery problem....
sometimes symptoms are
time/date will reset to some 1990 date after cold boot
or wouldnt even boot to windows, cos u lost all your settings
if the bios settings retain, battery should be still good
Offline qflyer
Re: help pc problem
« Reply #12 on: February 01, 2019, 20:41 »
I have reinstalled the windows os and yet the problem persists.
What is happening to my pc.
Re: help pc problem
« Reply #13 on: February 01, 2019, 21:28 »
This is one sign of virus infection. Better shutdown before more damage is done. Then find a way to backup important files.
help pc problem
« Reply #14 on: February 01, 2019, 21:31 »
If faced with this sort of situation, I would take out the HDD. Put the HDD into a HDD dock. Attach HDD as external disk to a laptop. Scan for virus and fix. Copy out important data files. After that I will nuke the HDD and install fresh copy of Windows. If possible use original Windows on CD, not some downloaded slipstream version that may have embedded virus. Nowadays the virus sibei scary one.
« Last Edit: February 01, 2019, 21:34 by Boxerfan88 »
