Author Topic: Standard screen vs Tap tension screen Motorize type  (Read 907 times)
Offline alf
    • www.entheos.com.sg
« on: January 31, 2019, 15:37 »
A separate thread on Motorize Standard Fiberglass type versus Tap tension
I am experimenting the 2nd generation Cyrus cine projection screen , new motorize system with even larger roller bar , heavy drop bar and a more silent motor ( 25 % larger than conventional motorize type ) On both fiber glass 4k surface and another is tap -tension with the same mechanical structure . Both also have longer black drop .
I have manage to install the fiber glass material very happy with result . Tomorrow will install the tap tension and see if it is to my expectation , keep my finger cross . ( sorry self shiok )
Any way as I have shared earlier each products has it place just have to be more meticulous during purchase , check the room humidity level before buying a tap tension screen .
Do remember when you buy a projection screen it will be a Long term investment and when you incopperate to your design of your home . Placement is key , follow by installation position and will it cause amplified sound , service maintained and repair , will the flatness last along time . If buying a good well made screen it will last you a Long , Long time with the lease problems .
Can share the current screen problems or picture what are you are un happy on you current projection screen .
Offline alf
Re: Standard screen vs Tap tension screen Motorize type
« Reply #1 on: January 31, 2019, 17:02 »
Standard Fiberglass base with larger mechanics .
« Last Edit: February 01, 2019, 12:06 by alf »
Offline alf
« Reply #2 on: January 31, 2019, 17:13 »
Tap Tension screen with larger mechanics.
« Last Edit: February 01, 2019, 12:07 by alf »
Offline ranjiths26
« Reply #3 on: February 02, 2019, 19:41 »
How much are these screens and where to buy? Thanks
Sent from my Pixel XL using Tapatalk
Offline alf
« Reply #4 on: February 03, 2019, 20:36 »
Hi Ranjiths26,
You can always come by to my  Display area for the demo of the standard screen , on my service centre where you can see the Tap tension of display . There is also a training room where you can see the different type of fixed screens.
See which is best to suit your taste and application on the projection screen needs .
Entheos LLp ,
Blk 18 , Sin Ming Lane  # 07 -10 S( 573 960 ) Midview City
Please whats me so can send you the Map of how to get to my unit .
