Author Topic: My 2020 HT Upgrade Journey :)  (Read 16022 times)
Offline rock123
    • Bass EQ for Filtered Movies
Re: My 2019 HT Upgrade Journey :)
« Reply #15 on: June 25, 2019, 11:29 »
KLF-30 with dual 12" drivers + Tweeter and Mid range Horn
« Last Edit: March 27, 2020, 01:11 by rock123 »
Offline synthesis
« Reply #16 on: June 25, 2019, 13:46 »
I think even a flea amp can drive this big floorstander....
Offline rock123
« Reply #17 on: June 25, 2019, 23:03 »
The speakers are heavy and tall.
Really very efficient and can be driven to HIGH volumes yeh i think even with low powered amps, but do well with high powered amps.
They sound fantastic and sweet for music too.
Offline Chowbotak
  • Trade Count: (+7)
« Reply #18 on: June 27, 2019, 13:26 »
Is that a real plant? Can survive the low bass? ;D
Offline rock123
« Reply #19 on: June 27, 2019, 15:26 »
haha it's a fake plant bought from Ikea bro :) Greenery environment + add on :)
Offline rock123
« Reply #20 on: June 27, 2019, 15:30 »
Just finish the Front Stage LCR of my humble setup. + KLF-C7 Center.
I must really thank the community members of this form that I have learnt lot of tips and ideas and calibration etc.
With the sharing and can really felt and see the passion of some bros here, I have enjoyed the HT Journey
Thanks so much.
Am happy that we have this forum and sharing and enjoy the fruits is most important!
Enjoy HT bros.
« Last Edit: March 27, 2020, 01:14 by rock123 »
« Reply #21 on: June 27, 2019, 21:05 »
Glad to see that you are enjoying the fruits of your labor. :)
Offline kennyluck2000
« Reply #22 on: July 27, 2019, 13:26 »
Last night, i was given a privilege to be invite by Rock123 to have a listen to his newly setup.  ;)
One word i will describe about his bass... it's massive.... :o it will shake every loose parts in the house... :o :o :o
One unit Rythmik 15", One unit Rythmik 18" and One unit SVS dual 12" down firing... with these 3 subs on you get the feel that the whole house is gonna broke down anytime... :o :o :o
My advise to other forum members who plan to visit Rock123 is better to get helmet prepare before entering Rock the House... ;D ;D ;D
We also when through with only 1 sub on. Just with one of these sub on, each of this individual sub are capable of getting you with those kind of tactile feel to your body... 8) 8) 8)
Rock123 is definitely consider one of the massive basshead guy... whack until there is no tomorrow.... ;D ;D ;D
Offline rock123
« Reply #23 on: July 27, 2019, 13:57 »
u guys are welcome anytime.
It's just a simple 7.3.4 HDB setup which luckily my 5rm hdb living hall is big enough to fulfill.
To me, big space is needed to have such a big speakers + surround with more space to breathe.
To be v frank , i dont care about my windows, doors rattling or REW stuff.
IF I move house 1 day, will focus on room treatment + compact 5.2.2 setup.
Just pure vanilla listen and hear what i Like. Most important is just enjoy bah.
PS : I will need to improve on my LCR to have a more clarity sound  ( appreciate u guys fb) no worries
Enjoy HT guys!
« Reply #24 on: July 27, 2019, 14:45 »
Enjoy HT guys!
Not the LCR issue... the overall SQ has to have a balance... sometime the bass too overwhelming cover the Front sound stage. Just by lowering your bass on the AVR or increase 1 to 2 db on the LCR and surround at the AVR and listen again... repeat the process unit you get the effect and sound stage you want... this is personal preference... don't have to follow what we thinks it should sound. This is just a suggestion and not a must to change your setting.... Enjoy your system...and enjoy your life... 8) 8) 8)
By the way My CF-3 is ready for you to have a listen.. 8) 8) 8)
« Last Edit: July 27, 2019, 14:58 by kennyluck2000 »
Offline rock123
« Reply #25 on: July 27, 2019, 15:04 »
good suggestion advice noted. will trial test calibrate agen. :)
Vintage rules. :)
Offline rock123
« Reply #26 on: August 10, 2019, 23:10 »
Since it's a long weekend, fine recheck my setup on the following:
1. Plug in Power Amp directly to DA&T AC filter   :)
2. Notice 1 Nordost Blue Angel Interconnect cable plugged in wrong direction for L.............
3. Swap to use Nordost Blue Heaven Interconnect cables for L & R Channel
4. Use 1 Nordost Blue Angel Interconnect cable for Center Channel
5. Recheck all L , C & R channels directional RCA Interconnect connections from AVR into Power Amp
6. 2 Rythmik Subs Volume on 1 o'clock  & SVS Gain on 11 o'clock
Just spent 1 hour on recalibration
1. Run Fresh Onkyo AccuEQ
2. Set L&R Full Range with double bass ON
3. Sub + 5db (instead of +1x before )
4. L & R + 1db
5. Center & Surrounds + 2db
Good to go.
PS : Use to run with Double bass OFF, but now with Double Bass ON :) Enjoy HT time!
Offline Breadman
« Reply #27 on: August 15, 2019, 16:47 »
I have heard of 5.1 or 7.2. What does Rock123 means when he said 7.3.4?
Offline lchua6
« Reply #28 on: August 19, 2019, 21:21 »
7 speakers, 3 subwoofers and 4 ceiling speakers
Offline Breadman
« Reply #29 on: August 20, 2019, 12:45 »
Thanks for the reply. Now i understand.
