Not sure but I'm using JVC very own 3D active shutter glasses (come as a bundled). I have to say that the 3D have come a long way for JVC and it had improved by leaps and bounds. Gone are the days of parallax error or ghosting. Bro Jeff, you getting the N7 yourself?
Thx Des for ur views. Yup just have to try for ourselves once new projector arrives n decide then.My ht setup in my hall so now figuring out where to place my fixed screen when not watching movies, as my previous pull down was places in front of tv console. Furtunately i have 2 separate walls to hang the fixed screen when not in use.... but not sure how tedious it will be to move the screen each time, but i am digressing here
jeffong,If it is not a 100" screen, i think you will get better mileage going with a large screen TV.Size is everything...... (Audio)
Hi Hero ,To look neat you can stick back to manual pull down the better choice will be a motorize screen .On the fixed type you can use a fixed screen with stand with wheels or other option wire hang down on top down , when not in used can hang over the other side . Hope that helps .
Thanks Alf. Motorised screen with tab tension too costly for me. Also, I hate all the squished bugs over time which is inevitable when using a rolled up screen. I wanna go for fixed screen this time to get the optimal viewing experience from the N5. I reckon a smooth 'texture free' screen is essential because from my calculation, each 4K pixel will be approximately 0.6mm x 0.6mm when projected on a 106" screen.
When it's late and way past ur bedtime after a movie, the last thing on your mind is to check for bugs hiding on your 106" screen, especially the back of the screen which is all BLACK ah I should know since i have been using 106" screen (dalite and remaco) since 2011. Love every inch of it. Still do after all these years. Have absolutely no desire to look at those 60, 70, 80 inch TV displays at the shops. And since my family and I love big screens so much....... we just took the plunge and got the N5, with a litle nudge from our current projector ae7000 which just so happen to die on us. It's fate lah
