Author Topic: Where to buy M-Cap for speaker crossover caps?  (Read 3120 times)
Offline wyx03
« on: December 29, 2018, 16:49 »
Hi, anyone care to recommend where can find this M-Cap for speaker crossover? Is the pricing from partsconnexion reasonable?
Thx....Happy New Year!!
Online watchdog
  • Trade Count: (+6)
Re: Where to buy M-Cap for speaker crossover caps?
« Reply #1 on: December 29, 2018, 17:34 »
Robert from Liveacoustics carries them.
Less is more !
Offline wyx03
« Reply #2 on: December 29, 2018, 22:23 »
Any idea if partsconnexion pricing is reasonable? Might just order if pricing not too far from local store. Plan to buy about 20~30 pcs with slightly different values to try.
Thx for replying :)
Offline synthesis
« Reply #3 on: December 30, 2018, 00:03 »
You also can check Madisound price.
Offline wyx03
« Reply #4 on: December 30, 2018, 12:28 »
Thx for the pointer. Great online store for DIY parts with good price. Unfortunately, it doesn't carry Mundorf lower end MKP caps.
https://www.partsconnexion.com/capacitors-film-mundorf-mkp-series.html
Will place order by this week if can't find alternative source. Thx for your time. Happy New Year!!
Offline jaffrie
« Reply #5 on: January 01, 2019, 19:25 »
Don’t overlook the importance of resistors on the XO,
you’ll be surprise in the ways it affects the timbre.
Offline wyx03
« Reply #6 on: January 02, 2019, 08:50 »
Plan to order the resistors to inductance-free type. Will parallel them to make up the original resistance. 20W rated Mundorf resistors cost 8x the price of 10W resistors https://www.partsconnexion.com/mundorf-mr10-series-10-watt-resistors.html
« Last Edit: January 02, 2019, 08:54 by wyx03 »
Offline jaffrie
« Reply #7 on: January 02, 2019, 11:17 »
When I was upgrading & mucking around with the XO on my ML Odyssey, I tried a number of resistors namely Mills wire wound, Jantzen, Mundorf Supreme & Powetrons resistors. Ended up using mostly Powetrons & 1 Mundorf Supreme. Powertrons are very fast, grainless & transparent. Supreme have some emphasis towards the highs.
You’ve got to experiment to get the best sound as eash speaker is different. Mills are nice sounding but somewhat slow & is not that transparent but then again these findings are for my speakers.
Offline wyx03
« Reply #8 on: January 04, 2019, 23:30 »
I did a quick online search on Powertron resistor. They are much more expensive than the inductance-free Mundorf resistor. Can't justify for my budget Usher S520 speakers. Anyway, thank u very much for sharing  :)
Offline alamakazam
« Reply #9 on: January 04, 2019, 23:37 »
with this statement... mundorf upgrade vs s520 is not worthwhile also...
Offline wyx03
« Reply #10 on: January 05, 2019, 11:05 »
I think different types of cap will produce more significant change in sound character than resistor. Mundorf M-caps are cheap, so no harm trying.
Offline jaffrie
« Reply #11 on: January 05, 2019, 19:40 »
When I bought Powertrons they were only 60% of the cost of Mundorf Supreme. Perhaps you can try some
Caddocks which Parts Connexion have them for sale.
Offline wyx03
« Reply #12 on: March 04, 2019, 17:45 »
Decided to get Bennic FPP caps directly from Bennic Taiwan for my speaker Xover mod. Will fly out to Taiwan this week and return 2~3 weeks later. Will collect the caps from Bennic Taiwan Sales guy if the price is reasonable as compared to Mundorf MCAP. Let me know if anyone interested to get some for your DIY projects.
https://www.bennic.com.tw/en/filmcap/22fppupp.asp
« Last Edit: March 05, 2019, 15:52 by wyx03 »
Offline hyper
« Reply #13 on: January 07, 2020, 09:48 »
Where can I find Obbligato Premium Gold caps in Singapore?
Offline matty
  • tubey day!!!
« Reply #14 on: January 07, 2020, 13:11 »
Robert at liveacoustics
