Author Topic: Sonos speaker  (Read 3033 times)
Offline qflyer
Sonos speaker
« on: December 22, 2018, 22:30 »
I can’t believe it all sonos speakers cannot be connected via Bluetooth. In an event my wifi is down I can still have Bluetooth connection. Just don’t know what sonos is thinking of? ??? ???
So I gave up buying sonos one.
Offline qflyer
Re: Sonos speaker
« Reply #1 on: December 31, 2018, 13:50 »
Creative iroar speaker no WiFi either, hopefully next design with it and google hone too.
Offline zephyr11
Re: Sonos speaker
« Reply #2 on: January 03, 2019, 09:01 »
honestly didn't know, but definitely good to know.
thanks.
Offline qflyer
Re: Sonos speaker
« Reply #3 on: January 11, 2019, 20:36 »
Here’s the alternative
https://sg.yamaha.com/en/products/audio_visual/desktop_audio/musiccast_50/index.html
Only Alexa no google assistance. Maybe I should just buy the google speaker or wait for portable model.
Offline qflyer
Re: Sonos speaker
« Reply #4 on: January 12, 2019, 21:53 »
Offline Basshead
Re: Sonos speaker
« Reply #5 on: January 13, 2019, 22:31 »
Wah Meridian sia don't play play...
But I love the Musicast interface, damn easy to use.
Offline mingzhen
Re: Sonos speaker
« Reply #6 on: January 17, 2019, 10:40 »
I have tried many WiFi Bluetooth speakers in the market. If u want WiFi + Bluetooth, the alternative to Sonos is Yamaha’s latest MusicCast 20. Only the MusicCast 20 that sound good to me, other model or previous version are not that nice. MC20 can also be set to stereo mode via WiFi which sound pretty good! With MusicCast Sub 100, u can have a 2.1 system wirelessly, which is very cool!
Offline qflyer
Re: Sonos speaker
« Reply #7 on: January 17, 2019, 18:30 »
Sure I’ll take a look.
https://www.denon.sg/sg/heos1hs2
Waiting for this with google assistance.
https://www.cambridgeaudio.com/gbr/en/products/yoyo/yoyo-m
Just saw this.
« Last Edit: January 17, 2019, 18:51 by qflyer »
Offline qflyer
Re: Sonos speaker
« Reply #8 on: January 17, 2019, 21:15 »
Even kef is on the bandwagon
https://m.int.kef.com/products/muo
Offline qflyer
Re: Sonos speaker
« Reply #9 on: January 30, 2019, 19:44 »
I just heard these speakers
https://www.lg.com/sg/home-audio/lg-PK3
The worst and
https://www.lg.com/sg/home-audio/lg-PK5
The best, while kef muo sits between the two
https://www.whathifi.com/kef/muo/review
Offline Audiolab
Re: Sonos speaker
« Reply #10 on: January 30, 2019, 19:58 »
I am using the JBL Link 300 with Google Assistant. Very happy with it. Not sure if it meets your need. Main purpose for me is Google Assistant (control my home automation) and stream music on Spotify and Tunein with Google Assistant help. Comes with Bluetooth also.
They also have portable version like Link 10 and 20.
Offline qflyer
Re: Sonos speaker
« Reply #11 on: January 30, 2019, 20:07 »
Yeah I forgot about the jbl 10 & 20. I heard them better than kef muo.
Offline Audiolab
Re: Sonos speaker
« Reply #12 on: January 31, 2019, 08:30 »
If you do not need portability and waterproof, the Link 300 is a much better sound speaker. Has good bass from the passive radiator and play loud enough to fill medium size room if needed.
Offline qflyer
Re: Sonos speaker
« Reply #13 on: January 31, 2019, 09:57 »
yes i need portability
Offline qflyer
