Author Topic: PARASOUND HINT 6 Integrated Amplifier @ Audio Basic  (Read 233 times)
Offline Audio Basic
« on: December 07, 2018, 13:45 »
Dear Friends,
The latest Parasound HINT 6 Integrated Amplifier has arrived !
*** New Features (Changes from the original Halo Integrated):-
Burr Brown analog resistor ladder volume control
Dimmable front panel volume display
Updated USB receiver is Plug and play with Windows 10 and MAC
An additional optical input (2 total)
Ball bearing supported solid aluminum volume knob
Programable default turn on volume setting
Favorite volume memory with remote control button
Increased phono stage gain for lower output cartridges
Improved Left/Right channel separation and balance tracking
Updated cosmetics with subtle gold highlights
*** Preamp and DAC Features :-
ESS Sabre32 Reference DAC (ES9018K2M)
Asynchronous USB 2.0 supports PCM up to 384kHz/32-bit
USB input decodes Native DSD64, DSD128, DSD256 and DoP DSD
Coax and optical inputs accept PCM up to 192kHz/24-bit
Analog bass management with high & low pass crossovers
Home theater bypass input for surround sound integration
Front panel subwoofer level control
Dedicated high current headphone amplifier (TI TPA6120)
Phono input for MM, MC and MI with 100 Ω or 47k Ω load
Front panel Aux input with automatic +12 dB gain stage
5 pairs RCA line level Analog inputs
1 pair XLR balanced Analog input
Balanced XLR and RCA left and right preamp outputs
1 balanced XLR and 2 RCA subwoofer outputs
Bass & treble controls with relay bypass from remote or front panel
Rear panel IR input and IR loop output jacks
12 Volt trigger output
Back-lit remote control with discrete buttons
0.5w standby power consumption meets Energy Star & EU specs
*** Power Amp Features :-
160 Watts x 2 @ 8 Ohms (RMS, both channels driven)
240 Watts x 2 @ 4 Ohms (RMS, both channels driven)
Power amp circuit topology designed by legendary John Curl
Direct amplifier input to bypass preamp section
High bias class A/AB operation
Oversized shielded toroid power transformer
Dual-mono power supply and power amplifier
40,000uF power supply filter capacitance
Matched JFET input stages and MOSFET driver stages
12 high voltage/high current bipolar output transistors
Heavy-duty 24k gold-plated 5-way speaker binding posts
Over temp and short circuit relay protection
Selling Price @ S$4500
Audio Basic
1 Coleman Street
#02-12 The Adelphi
Tel : 6338 3245
Audio Basic
1 Coleman Street
#02-12 The Adelphi
Singapore 179803
Tel: +65 6338 3245
Visit our Facebook @ Audio Basic
