Author Topic: McIntosh 70th Anniversary Limited Edition C70 and MC2175 tube preamp & poweramps  (Read 1147 times)
Online Doggie Howser
Soo bloody chio
https://www.stereo.net.au/news/mcintosh-celebrates-70th-anniversary-with-new-pre-and-power-valve-amps?fbclid=IwAR3Glz3irAg-fAXFPIAQvoTVVsfTuBtOURrv7gdeULvCLOncyuhIxNz-mfo
Only 70 sets to be built. I sent the photo to a guy I know this morning and he's been allocated THE ONLY ONE in Australia. So lucky. I am sooo envious
carbon fibre - heart attack!!
so chio
Online domho8
Woo those tubes chin swee ah.
How muchie
Sent from my Redmi 5 Plus using Tapatalk
Offline Chericelise
How muchie
I estimated around $30k for the set.
Online domho8
Whoah 30k. I must ask my mil for a loan.
:D
Offline BlurRhino
I highly doubt that it will be just 30k when the USD rrp is 22k.. the mark up from local distributor for Mcintosh is always eye watering exp.
Over in Australia, you have to buy the Limited Edition pre and power as a set. A$44k for the two.
There is only ONE per distributor. And the one here was already sold. And I heard two more are asking to see if they can get one. But nope. 70 sets.
You'd be lucky if you could still get the Singapore allocated one I think.
Offline ohlins
  • a crown for every achievement
    • my watch and audio blog
can buy the regular versions on its own  ....
"After the 70th Anniversary Limited Edition Commemorative Systems are sold out, the MC2152 70th Anniversary Vacuum Tube Amplifier and the C70 70th Anniversary Vacuum Tube Preamplifier will be available separately." ....
the hype is true...listen at your own risk
visit http://oohlins.blogspot.com
I was told construction/materials may change.
Offline ohlins
maybe change abit ........ just like SL-1200GAE and SL-1200G?
Offline Jagdpanzer
  • HT & Audio
Problem is that McIntosh did not stick to its original point to point wiring using premium parts but instead use PCB boards with much process controls
