Author Topic: Recommend cables and where to buy  (Read 4751 times)
Re: Recommend cables and where to buy
« Reply #30 on: December 06, 2018, 09:55 »
Spades are the best as it allow for the maximum area of contact.  The screws enable high pressure to be applied, compressing and eliminating uneven surface contact, pushing the mating surfaces to bite into each other.
Banana is perhaps the worst  because it only allows point contact and rely on spring pressure.   Even the WBT expanding banana jack will still lose out to the spade.
« Reply #31 on: December 06, 2018, 10:18 »
Thanks for your recommendations.
I had already gotten Belden speaker cables and the electrical cable from LHS before I saw this.
One question about banana plugs... what benefits do they give besides the convenience when plugging?
I was going to go plugless.
gold plated banana plugs offer to tweak the sound signature to being warmer
platinum plated ones offer improved dynamics.
rhodium ones with speed and better decay.
Silver one better details
the quality of the material use on the banana plug itself is also crucial to how your system will sound.
cheap brass vs pure copper vs pure silver. there IS that obvious difference.
ProJect Q.
Offline WuffRuff
« Reply #32 on: December 06, 2018, 14:11 »
Banana plug has few prices ranging from $1 up to $15 per piece or even higher.
Have you ever seen corroded banana plug? what will you think if it is connected to your setup?
Best is a direct plug but there is a risk of being shorted to the case, therefore, I use a good banana plug at AVR side then plug directly at speaker side.
(BTW, I also don't like to use a condom, direct 'plug' in is always best, direct contact, hehehehehe... ;D )
I like the idea of direct too and I have always used direct to both ends and never had an issue.
Are you able to elaborate more on the shorting?
How and why does that happen?
Offline WuffRuff
« Reply #33 on: December 06, 2018, 15:09 »
- HDMI cables  - Both normal and active
Recommend to buy from Monoprice. They have certified 4K cables that are ultra slim. Just brought a bunch and all working well. Their active cable has been very reliable so far. If u need only short run, buy their 8k certified cable.
I saw that Monoprice is US website?
I can't wait long for the cables to arrive as they want to run it already.
Local online stores still possible.
Anyone knows also good local online stores to get HDMI cable?
Online Jag
« Reply #34 on: December 06, 2018, 16:30 »
If you need good and immediate, go to LHS at Sim Lim Tower. Ask for Belden cables and Robert will give you reasonably good value for money.
They are not bargain basement cheap, but reasonably good quality for the price.
« Reply #35 on: December 06, 2018, 16:58 »
prices from LHS is FIXED. no more bargain. if you dun need it dun buy. i love and hate this type of attitude. depending on which side you are on. they dun need small scraps. mindset change. so i no longer buy from them.
ProJect Q.
Offline francis wu
« Reply #36 on: December 06, 2018, 17:23 »
Frankly, bare wire connections is fine, just keep a lookout on tarnish as it is exposed to the air!
Offline WuffRuff
« Reply #37 on: December 08, 2018, 04:42 »
Ahhh... I never had an issue with wire tarnish even when I was living opposite the sea and practically every metal part grew those green oxidation stuff but copper wires were good.
In my new place, I anticipate I would be turning on the air con quite frequently so this will keep humidity down and reduce the likelihood of tarnish.
I guess no issues running bare then.
Offline francis wu
« Reply #38 on: December 08, 2018, 09:40 »
Nope, I m running bare on my speakers too....enjoy your set up :)
Offline WuffRuff
« Reply #39 on: December 31, 2018, 00:21 »
Any recommendations for 10m active HDMI cable?
Online Jag
« Reply #40 on: December 31, 2018, 08:19 »
Amazon. Monoprice fiber HMDI or Ruipro fiber hdmi. Fiber HDMI is the way to go for such long hdmi runs in the 4K UHD world.
Offline cleadett
« Reply #41 on: December 31, 2018, 17:38 »
what is min length of fiber optic?
I wonder, how can the light be used in the digital domain compare to silver copper cable?
Online Jag
« Reply #42 on: January 01, 2019, 08:24 »
Anything above 5m is when I would start looking towards fiber.
« Reply #43 on: January 01, 2019, 09:08 »
<a href="http://www.youtube.com/v/puhlj_jNtp8&fs=1" target="_blank" class="new_win">http://www.youtube.com/v/puhlj_jNtp8&fs=1</a>
« Reply #44 on: January 01, 2019, 09:12 »
Vincent's "dry sense" of humour is getting weirder...LoL.
"or thick like snake..."
