Author Topic: Recommend cables and where to buy  (Read 4025 times)
Offline WuffRuff
« on: November 30, 2018, 11:51 »
I would greatly appreciate if you could recommend me value for money which brand and type and where to buy for the following cables:
Can be store or online also.
- Speaker cables 16 and 12 AWG
- HDMI cables  - Both normal and active
- Ethernet Cat6
- Electrical wiring for dedicated electrical line
- Banana plugs (not a cable but related)
Thank you heaps!
Offline chaozhoi
Re: Recommend cables and where to buy
« Reply #1 on: November 30, 2018, 12:18 »
- Ethernet Cat6
Thank you heaps!
LHS Sim Lim tower. Look for Robert. Canare or Belden
Sent from my ONEPLUS A5000 using Tapatalk
« Reply #2 on: November 30, 2018, 13:06 »
I personally have handshake issue when was using cable from robert
sinlim.. bcoz of long length cable 8m.. i tot it was due to my Sony PJ.
... Sony recommended not to use more than 5m...
End up,  I use ACTIVE HDMI cable to solve this handshake issue..
If you use TV, shouldnt be a problem coz tv have built in signal amp.
« Last Edit: November 30, 2018, 13:08 by whitesox »
Offline chaozhoi
« Reply #3 on: November 30, 2018, 14:10 »
I am also using Sony projector and Robert's HDMI cable. No issue so far. *Fingers crossed*
Online Audio
« Reply #4 on: November 30, 2018, 15:18 »
« Reply #5 on: November 30, 2018, 16:40 »
What is the length of ur hdmi cable?
Offline chaozhoi
« Reply #6 on: November 30, 2018, 16:41 »
Forgot either 7 or 9 or 10 I think. It's a Belden cable. LHS was selling 2 types of HDMI.. he has redmere cables also
« Reply #7 on: November 30, 2018, 17:47 »
- Ethernet Cat6
Thank you heaps!
The most mentioned budget speaker cables in this forum is Belden. Personally, i prefer Klotz or Van Der Hul Silver line for the front 3 channels. If ur budget allows, go up to the Jap makes from CANARE or FURUTEC.
Interconnects for coaxial digital, most mentioned is Audioquest.
As for HDMI, lots of members in XP believes in price is true logic, hence the popularity of FIBBR cable. However if your budget is tight, and ur source equipment is too far away from ur screening device, go for version 2.0 HDMI. Typically for 4k image, version 1.4 is enuff.
Offline Knight_Rider
« Reply #8 on: November 30, 2018, 21:10 »
Fibbr china distro is in TB
https://ymav.taobao.com/category-1225151023.htm?spm=2013.1.0.0.7222255dzdp05Z&search=y&catName=FIBBR%B7%C6%B2%AE%B6%FB
Offline chaozhoi
« Reply #9 on: November 30, 2018, 21:26 »
Unless u r really going for very long run, I dun think need to use fibbr.. redmere should be fine. Imagine the spare length from the 25m cable
Offline WuffRuff
Offline WuffRuff
« Reply #11 on: December 01, 2018, 11:08 »
Thanks for the replies.
Have a much better idea now.
Anyone knows anything about the electrical wires for the sockets of dedicated electrical line?
« Reply #12 on: December 01, 2018, 12:22 »
You trust it to be authentic?
if u do a search in this forum on FIBBR owners... Perhaps u may discover that they go straight for the source?
« Reply #13 on: December 01, 2018, 17:03 »
Authorised Distributor. You ask a question I give a lobang. If you think is a scam buy from Amazon (probably the same dealer as well). The cable is from wuhan anyway.
Ok this wan no scam
https://shop137250997.taobao.com/
« Reply #14 on: December 01, 2018, 17:07 »
He doesn't know Fibbr is from China
https://www.fibbrtech.com/index.php
Flagship store is in TB
