Author Topic: Best way to Clean your stylus..  (Read 1698 times)
Offline Indising
Re: Best way to Clean your stylus..
« Reply #15 on: December 02, 2018, 23:31 »
https://audiosolutions.net.au/product/ds-audio-st-50-stylus-cleaner/
Like Vinyl Passion in principle but designed to be slim to fit on most platters. Vinyl Passion is too thick to fit
This "looks" very much like the earthquake resistant mats from Daiso. Although never tried....dont intend to take the risk either....may be can try when carts worn out and about to replace
Offline Jagdpanzer
  • HT & Audio
« Reply #16 on: December 03, 2018, 07:26 »
Stay clear of Daiso EQ resistant gel if possible - even for anything you want to try. It's absolute madness if you use it on stylus. It's sticky and gooey and you will spend more time removing the sticky residue in our humid climate.
Offline Indising
« Reply #17 on: December 03, 2018, 21:19 »
:D
Offline Indising
« Reply #18 on: January 13, 2019, 20:22 »
There's also the Audio Technica AT637 electronic stylus cleaner and some Last Solution No.3.
Have the AT607 cleaner solution....although haven't used it for a few months already (was told its not good for stylus). so far been managing with the free brush (Hana) and Mofi brush for stubborn dust
Is it true its not good for stylus?.... is it good to use this once in a while?
Offline milk_vanilla
« Reply #19 on: January 14, 2019, 08:48 »
I use DS, after zerodust worn out.
Both are doing good job,
DS is slimmer than zero. Could benefit if the height between your cart/arm and platter is short.
