Author Topic: Best way to Clean your stylus..  (Read 1736 times)
Offline Ilovehifi
« on: November 24, 2018, 20:03 »
Beside using the brush..
What other best method...
Offline lcheetec
Re: Best way to Clean your stylus..
« Reply #1 on: November 24, 2018, 20:18 »
I've used something similar, something you lower your stylus into...
Vinyl Passion Dust Buster Polymer Gel Stylus Cleaner https://www.amazon.com/dp/B004VEORZ0/ref=cm_sw_r_cp_apa_hfu-BbT90Q687
Sent from my MI MAX 3 using Tapatalk
« Reply #2 on: November 24, 2018, 21:22 »
https://audiosolutions.net.au/product/ds-audio-st-50-stylus-cleaner/
Like Vinyl Passion in principle but designed to be slim to fit on most platters. Vinyl Passion is too thick to fit
Offline DIYer Straits
  • 6h30p Über Tube
« Reply #3 on: November 25, 2018, 06:49 »
Zerodust, after using a modified fine hair cosmetic brush to clean off the big stuff.
There's also the Audio Technica AT637 electronic stylus cleaner and some Last Solution No.3.
But just using the brush is sufficient most times.
EDIT:
I've just read that some vinylheads online have been using those cheap melamine sponges as stylus cleaners. Has anyone here tried it?
I was looking for a cheaper DIY solution to Zerodust (Feck, those buggers are now so expensive?!) and came across it being mentioned several times.
« Last Edit: November 25, 2018, 06:55 by DIYer Straits »
Laptop via XMOS
Dual AK4495 DAC
Custom 6N6p Aikido Preamplifier
Modded TPA3118 Class D amplifier/ TPA 3255 power amplifier
Modded Thiel CS2.4/Modded ATC SCM-7/Some Satori in birch ply cabinets with a PR/KEF R300
To be updated
Offline BTW
« Reply #4 on: November 25, 2018, 07:10 »
EDIT:
Yes those Magic sponge make excellent stylus cleaner.. just be careful when using it.
Offline Jagdpanzer
  • HT & Audio
« Reply #5 on: November 25, 2018, 09:28 »
https://youtu.be/8sftZP6wUlE
DS audio ST50 and its $150 which you can use forever.
Reusable and no stickiness to stylus
Anyone wish to do a mass order?
« Last Edit: November 25, 2018, 10:24 by Jagdpanzer »
« Reply #6 on: November 25, 2018, 10:21 »
Thats the one I use
Offline malsound
« Reply #7 on: November 25, 2018, 14:21 »
<a href="http://www.youtube.com/v/bwhymznkWNw&fs=1" target="_blank" class="new_win">http://www.youtube.com/v/bwhymznkWNw&fs=1</a>
I swear by it as I am one who those guys that clean once every sides and have verified with leica microscope from work. Enjoy it doing bj on my stylus on every flip side. ;D
Offline silencer13
  • I have found Audiophile Nirvana and it cost me $40
    • Tokyo Fantasy Online Toy Store
« Reply #8 on: November 25, 2018, 15:00 »
Correct me if I'm wrong, but looks to me like the Vinyl Passion, DS and Zerodust are all basically the same product in different packaging?
Offline malsound
« Reply #9 on: November 25, 2018, 15:41 »
All are polymer base but different recipe, they do harden with time. Then again they are the best stuff to keep the stylus in tip top condition .
Offline Pinky
« Reply #10 on: November 25, 2018, 23:45 »
I use the VP cleaner after every side. There are of course many variations of the same type of cleaner. I still have an AT 637 ultrasonic cleaner I bought decades ago but it rarely gets used since I changed from a brush to the VP type. The old AT is no longer made of course but Flux sell one that does the same job. I've heard that "Magic Eraser" gets good results but I haven't tried it as yet.
Offline Gondon72
« Reply #11 on: November 26, 2018, 11:41 »
interesting.  so which is more effective?  VP cleaner or Flux hifi cleaner? :)
In the process of searching for one cleaner.  not very sure which is better.
Online francishuang
« Reply #12 on: November 26, 2018, 12:51 »
To me, vp def cleans better than zerodust. Have not tried the ds audio 1 yet. Flux cleans the best for me, Looks like new aftet cleaning
« Last Edit: November 26, 2018, 12:54 by francishuang »
Shindo is Music
Offline malsound
« Reply #13 on: November 26, 2018, 13:25 »
Francis have you had similar symptoms  like  what Brian Gupton experience.
http://forums.stevehoffman.tv/threads/new-flux-hifi-ultrasonic-sylus-cleaner.462751/
« Last Edit: November 26, 2018, 13:31 by malsound »
Offline Pinky
« Reply #14 on: November 26, 2018, 15:49 »
I VERY rarely use my old AT ultrasonic cleaner, simply because the VP gel does the job just fine for me. The AT was bought in a different age where stylus cleaning was mostly just a quick go over with a small brush and maybe some proprietry liquid on occasion. Times have changed in stylus care technology and for once it seems to be for the better.
