Author Topic: Reliable Contractor or Supplier  (Read 2405 times)
Online ysl
« on: November 17, 2018, 11:42 »
Rain is getting into the house from around the window frame. Could be a crack in the window, could be the trim/paste along the perimeter of the frame. Raining season and rain is getting into the house.
Any advise / sure of your experience, and looking for recommendation for a reliable contractor. Please let me know if you know of any.
Ford Road/Meyer Road area.
Thanks fellas !
« Last Edit: November 27, 2019, 16:53 by ysl »
Offline Octave
Re: Reliable Contractor for Leaking Windows
« Reply #1 on: November 17, 2018, 12:18 »
If gap or crack on the wall in between the window outer frame then can diy repair with this:
http://olympus.com.ph/166-tonytheme_cloudzoom_big/alteco-epo-putty-two-part-type-adhesive.jpg
« Last Edit: November 17, 2018, 12:50 by Octave »
Online ysl
« Reply #2 on: November 17, 2018, 19:19 »
Thanks Octave, exactly what I am thinking of, just do not have the word... Putty.
anyone else with similar experience, or knows how to, or know of a contractor, appreciate some directions.
Thanks !
Offline synthesis
« Reply #3 on: November 18, 2018, 19:17 »
Online ysl
Online ysl
Re: Reliable Contractor at reasonable fees
« Reply #5 on: November 04, 2019, 18:30 »
Need to move a one L shape leather sofa and a 5 piece outdoor balcony set.
The charges from 2 quotes is pretty high I feel.
Heard La La Move is good at reasonable charges.
If you have had good experience with any , please let me know.
Also looking for reliable at reasonable charges for curtains contractors, particularly day curtains.
Thank you.
« Last Edit: November 04, 2019, 21:07 by ysl »
Online ysl
« Reply #6 on: November 26, 2019, 14:16 »
Need to replace a Fisher & Paykel clothe dryer.
Budget $450-$550, 6-7 kg.
Bosch seem to have good reliability online review. Electrical supplier is telling me LG is good.
Any tips and lobang ? Particular make and model ?
Harvery Norman extended warranty - anyone bought this ?
Thanks fellas !
Offline KopiOkaya
« Reply #7 on: November 26, 2019, 21:12 »
Electrical suppliers get more commissions from Korean brands such as Samsung and LG. Don't fall for it.
Bosch is good. I have my Bosch washer for 4 years already. So far so good (touch wood). Had 3 LG washers previously... Will not go back to LG again. Their circuit boards always got problem... 10 years warranty on motor no use.
Get the price from Harvey Norman. Call Goh Ah Bee or Maximum Credit for quotes. Usually both are quite competitive.
« Last Edit: November 26, 2019, 21:19 by KopiOkaya »
Cable termination and repair services for a reasonable fee. Whatsapp Larry at 98805223.
Offline dXter
« Reply #8 on: November 26, 2019, 21:52 »
On the contrary, my LG washer last 9 years already
Online ysl
« Reply #9 on: November 27, 2019, 13:53 »
Thank you both for letting me know your experience.
KopiOkaya, thanks also for sharing the information and names, saves me some running around and being taken for a free ride that I would not appreciate.
Offline chewed
« Reply #10 on: November 27, 2019, 15:00 »
My LG washer died exactly 1 month to 10 years
Sent from my MAR-LX2 using Tapatalk
Offline KopiOkaya
« Reply #11 on: November 27, 2019, 16:17 »
My first LG washer, made in Korea, lasted 6 years - died due to circuit board failure
2nd LG washer, made in Korea, lasted 4.5 years - died same as above
3rd LG washer, country of manufactured not stated (but I learned later it was made in China), lasted 4 years - died same as above
« Last Edit: November 27, 2019, 16:19 by KopiOkaya »
Offline dsj88
« Reply #12 on: November 27, 2019, 16:36 »
Another vote for Bosch. My fisher and Paykeyl  died after 5 years. In Singapore Panasonic lasted 9 years. Made in Japan then.
Online ysl
Re: Reliable Contractor or Supplier
« Reply #13 on: November 27, 2019, 16:53 »
I do not have good experience with Miele, and will avoid it by a thousand miles. Buying it is only the beginning , after sales is an absolute nightmare.
« Last Edit: November 27, 2019, 17:27 by ysl »
Offline nfnc
« Reply #14 on: November 27, 2019, 18:05 »
Fwiw, my old Bosch lasted >14 years. Only changed when the door seal gasket cracked & it was uneconomical to pay Bosch SG to replace it.
