Author Topic: My HT Journey resumes. Diffusors with SMT Wings  (Read 4784 times)
Re: My HT Journey resumes. Diffusors with SMT Wings
« Reply #60 on: December 31, 2018, 19:08 »
So which is more valuable in term of dollar spent vs gain
A Power conditioner
Or
Wings
Or they complement each others.
I’ll guess Wings...
Soekris dac1541 | DA&T A38  | Usher MD2+X616 | Orisun DD12 | Samsung PS50B850 |
Offline BadEnglish
  • Int 0x19
« Reply #61 on: December 31, 2018, 19:13 »
Wings take the lead!! Power Conditioner Plixir Elite 3000 is no slouch, but definitely the SMT Wings for me. Best to have both, which im currently using, very happy indeed, cant ask for more.....
Make sure you are not asking more else your bed room noise floor will hit the roof  ;D
Trying very hard to reproduce the music and sound that creative mixing-artists composed in the studios, at home with limited knowledge and resources.
Offline BadEnglish
  • Int 0x19
« Reply #62 on: December 31, 2018, 19:14 »
I’ll guess Wings...
You also have gotten wings 8)
« Reply #63 on: December 31, 2018, 19:14 »
I’ll guess Wings...
You are absolutely right, the Wings offers something that Electronics can never produce... Its just priceless and superb!
Im hearing details and separation so crystal clear that ive never heard before. Even the raindrops hitting the helmet, hitting the rock, all seperate types of sound could be heard. That sort of minor minor details. I have the Tannoy ST200 Super Tweeters sitting in front of the 2 wings, the airiness........... Unbelievable....
my only problem now is that suddenly the 65' TV feels way too small for the sound im experiencing.... sigh....
« Reply #64 on: December 31, 2018, 19:16 »
lol, bedroom noise floor cannot be controlled.... at least 70-75db, sometimes will resonate to 85db! lol
« Reply #65 on: December 31, 2018, 19:21 »
Next continued to seal off the room doors with batwings and this mini rubber gel thingy that blocks out noise at the bottom of the doors, had it in and out of the room...
Door slightly tighter to open close, make sure not too tight, double sided material that blocks out all the little holes... so much improvement now on Noise Floor....
Getting to the levels I want now... much much lower noise floor now...
Cost usd8/piece from amazon, simple to use and effective , brought down the noise floor a great deal, prevents insects from coming in, improves air conditioner air flow from leaking, Delighted indeed....
i got this simple to use Sound Proof Door Strip Door, USD8.99 2" Width X 39" Length (Brown)
https://www.amazon.com/gp/product/B07GRN1ZZZ/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Offline BadEnglish
  • Int 0x19
« Reply #66 on: December 31, 2018, 19:23 »
Update,  upgrade to get bestest ;D
Offline Began
« Reply #67 on: December 31, 2018, 19:25 »
It can be reduce with different types diffuser and absorber. Channel or LV. Some bedroom Gucci also ok
« Reply #68 on: December 31, 2018, 21:00 »
Nope. Am reading this thread with interest...
« Reply #69 on: January 01, 2019, 01:01 »
Bro
How did you apply your rock wool to avoid false ceiling vibrations?
Mine’s a work in progress.. maybe when it’s closer to the TOP I can invite you over too. Cheers
« Reply #70 on: January 01, 2019, 09:03 »
Bro
Morning Pete, Happy New Year 2019 to you !
I used the grid system like seen on pics, just like how some of the offices do. But you gotta inform your contractor to firmly anchor it, so the grid itself doesn’t rattle playing heavy bass. The contractor I’ve used is very experienced , he installs for acoustics companies, his price is also very good and reasonable, much cheaper than many.
When you put up the rockwool, it’s important to first identify the air flow resistivity of the rockwool you have purchased. Most often, people get confused with looking at the density of the rockwool instead. The lower the air flow resistivity value, the more effective it is. What u want is effectiveness in acoustic properties by using the right material rockwool. Check with the seller the air flow resistivity of the rockwool material
Next, you wanna leave an air GAP between the rockwool and the ceiling. This helps with trapping excessive bass energy and helps improve decay times. Between the rockwool and ceiling, I have an air GAP of 4-8cm, depending on how the rockwool is being stuffed into the ceiling. After mounting the Atmos speakers and cables, stuff all corners of speakers with the rockwool. This will help eliminate speaker boundary interference on ceiling
Finally, on the surface of the grid, u can try some diffusing panels, to reflect the mids and highs, this method will Ensure the room doesn’t sound too dead with all the rockwool stuffed inside. Why on the surface, because mid and higher frequencies have shorter wavelengths and the whole point of it is to scatter the frequencies over space and time. So again, important is to use the right diffusors, a temporal diffusor that scatters frequency over time. In this instance, I picked the BAD panels to do the job
That’s the template....
In short
1) pick the right rockwool material looking at air flow resistivity values
2) leave air GAP between rockwool and ceiling to trap excess bass energy
3) use diffusion on surface to scatter mids and highs without making room sound dead
4) rockwool to fill up GAP of speakers to avoid SBIR issues on ceiling
5) Ensure mounting is effective and tight to avoid rattling. drill extra holes to firmly anchor it
6) try to identify anything that contributes to noise, eliminate it where possible
Enjoy !!
« Reply #71 on: January 01, 2019, 09:27 »
Some info on the SMT Wings, this stuff works in the nearfield as well, this one was posted to you tube
<a href="http://www.youtube.com/v/F9ZrSjR_lgA&fs=1" target="_blank" class="new_win">http://www.youtube.com/v/F9ZrSjR_lgA&fs=1</a>
Published on Oct 14, 2018
It is said that the wing diffusors are designed for broadband diffusion in the near field and take benefit of the early reflections. Described in this pdf: www.hakode.se/wing/Wing-concept.pdf
As normally, microphone and listening distance for various broadband Schröder diffusors is 2-3 meters to avoid lobing and combfilter effects. We wanted to try how small "wing diffuser bubble" we could create without experience those negative proximity effects.
We managed to place the microphones as close to the wing panels as 15-20cm with retained absence of the negative effects.
A surprising and cool thing that got stuck on tape was that the placement of the soundsource in the room/the soundstage, was much more precise with the wing diffusors compared to the more unclear soundstage that the dry room revealed.
As mentioned in the pdf, it seems that lack of early reflections make a sound much more difficult to perceive, as they say, in a landscape covered in snow, rather then how everything becomes much more clear and easy to hear and understand, with the dense early reflections present.
In summary, the wing diffusers seem to be an alternative to obtain a high resolution and clarity in very small spaces.
« Reply #72 on: January 07, 2019, 22:42 »
Next up ...
Very high quality Finnish Birch Plywood made BAD panels... Being from Europe, formedylhyde emissions are safe for kids...
This will be ready come weekend, I hope I have the time to mount it, 16 pieces in total. haven’t really measured but definitely 2 pieces of it will sit at 50 degrees above centre channel. Th rest will flank the Atmos in ceiling speakers in a 595x595 grid system. Centre will be further flanked by SMTs... first reflection point on ceiling by BAD panels, floor will be carpet for absorption
Now itself the room feel is so different... taking it up to the next level with lyngdorf soon...
Close up view
One of it sitting on the seatons smt behind
Still thinking of combination to use...
That’s it for acoustics and lowering of noise floor, will share final pics once mounted on ceiling , it sits in front of the echophon A fiberglass backing panels
Offline sdds
« Reply #73 on: January 08, 2019, 08:02 »
Congra on the new installation n with lydnorf yr system will up another level 👍. N next Mk speakers ☠️☠️☠️☠️☠️
« Reply #74 on: January 08, 2019, 12:43 »
Congra on the new installation n with lydnorf yr system will up another level . N next Mk speakers
Bro u deep deep la, your recommendation all deep ... from seatons, to KK to plixir to lyngdorf to MK 300, all deep deep poison $$$
Super good the MK speakers for HT, definitely in the shortlist for future upgrade
