Author Topic: Low budget DVD player  (Read 3555 times)
Offline luff
« on: May 07, 2002, 23:11 »
Planning to get a DVD player, must be able to play OEM DVDs. No need for progressive scan and karaoke. Narrowed down my shopping list to
Samsung M108
Shinco 8700
Panasonic (Can't remember the model number at the moment :P)
Care to make a recommendation?
duckling
Re:Low budget DVD player
« Reply #1 on: May 07, 2002, 23:16 »
Offline limos
  • INFECTIOUS SUBSTANCE
« Reply #2 on: May 08, 2002, 00:37 »
Check with sonic.. He is selling his M108.
But if i were you, i'll get the 8700PS instead. I got it for $350 including GST at Merdeka last month. Look for Er. Nice chap.
In Case of Damage or Leakage Immediately Notify Public Health Authority
duckling
« Reply #3 on: May 08, 2002, 01:23 »
It's the same price if you're getting from Merdeka - IMM. That is if you're staying in the West. ;)
