Author Topic: XBOX ONE S/X THREAD  (Read 3465 times)
Re: XBOX ONE S/X THREAD
« Reply #45 on: November 06, 2018, 07:46 »
Hmmm... I tried plugging a HDMI from another BluRay player to a newly bought S at my colleague place... It keeps showing some kind of error... Could it be the what HDCP protection going on, or does the system needs a update on the firmware to be compatible to another device?
U have to be specific with the error pop up msg. For HDCP 2.2, it only indicate to user that the HDMI cable is not HDCP 2.2 certified if you tried to play a 4K UHD Blu-ray Disc.
The Blu-ray player where the hdmi cable u swapped to test out the Xbox S console, is it a normal Blu-ray player or a true 4K player? If it is the former, then the cable unlikely HDCP 2.2 certified.
Use a different HDMI cable preferably one that comes with the Xbox S console, 4K TV (bundled with HDMI cables) or players (even media player) that is able to playback 4K content.
Again, what TV you are using and make sure you connect to the right HDMI inputs in the TV that supports 4K HDR 60fps etc. All these are important details that you left out in your post. Get back to us with more info before we can advise.
Offline HT102
« Reply #46 on: December 02, 2018, 09:20 »
Hi, I am thinking of getting a Xbox One X to use primarily as a UHD player with my Sony ZF9.
I read that it had many issues in the past and some seems to have been fixed by firmware updates. Would appreciate any advice if it currently has any issue with the support Dolby Atmos and Dolby Vision on the Blu-ray App?
Thanks!
Offline Norman_Chan
« Reply #47 on: January 09, 2019, 18:44 »
It is a good price now...at times Challenger is selling about S$280++ during promotion on on 500gb hard disk version.
Offline foxz15
« Reply #48 on: January 11, 2019, 14:22 »
If u mean the Xbox One S .. U can try on Qoo10 seller "Qisahn" even u add on extra controller also cheaper then outside selling .. or u wait for the Qoo10 coupon even cheaper .. 🤗
Amps:EMOTIVA XSP-1G2 & DENON AVR-X7200WA
Power Amps:EMOTIVA XPA-100G2(x2) & ROTEL RB980BX(×3)
Sources:MARANTZ UD7007,NA7004,ROTEL RCD1070,PCH A-500 & XBox 1X
Speakers:JBL STUDIO 580, STUDIO 520, SAT 1 & 2
Active Subwoofers:JBL ES250(×2)
Cables:BELDEN STUDIO814, MONOPRICE CL2 Rated,
             MONSTER ULT V1000, M1000i, M2000HD & SINE ROYAL 2S(×12)
Visual:LG C8 55" & BENQ W1080ST+
Power Filter:G&W TW-DK166A(×3)
« Reply #49 on: January 11, 2019, 14:48 »
Thanks!
So far so good after the firmware update.
« Reply #51 on: January 31, 2019, 21:48 »
DTS:X coming
https://wccftech.com/windows-10-pc-xbox-one-getting-dtsx-soon/amp/
If playing 4K UHD bluray or gaming titles featuring DTS X...I don't think there is any support for this format by Netflix or Hulu.
