Author Topic: WHARFEDALE QUARTZ Q7 (BLACK) 150watts  (Read 319 times)
Offline sonicsoundaudio
« on: September 14, 2018, 21:24 »
http://www.sonicsoundaudio.com/product_info.php?products_id=2590
audit at orchard plaza 05-32/33
self collect orchard plaza 05-32/33
retail SGD$1499 now SGD$500 1pair
last 2 pair only new sets while stock last.
1 year warrently.
sms to 90889737
Wharfedale heavily invests in its design and is keen to maintain its stature in the international Hi-Fi market through innovative ideas and impeccable craftsmanship. A philosophy of ‘perfect balance of form and function’ is the core motivation for any design engineered by us. In this light Quartz speakers are made from the best technology available at a budget price.
The series is equipped with bass-midrange units which utilize a natural fibre cone fabricated to a precise formula and are specially treated to enhance midrange clarity. In the center of the cone is a phase plug that improves high frequency response and ensures seamless transfer of sound through the crossover region to the treble unit. The 1inch tweeter is made up of transparent silk dome and complements the drivers. The crossover is simple but effective, it ensures on-axis and off-axis performance over a wide listening area.
Specification
Format   Floorstanding
Bass Unit   2x165mm
Tweeter   25mm
Rec. Amplifier Power   25-150W
Nominal Impedance   8 Ohms
AV Shielding   No
Sensitivity (1W @ 1M)   88dB
Frequency Response (-6dB)   48Hz-20kHz
Size (HxWxD)   920x180x270 (mm)
Height with spikes   945 mm
