Author Topic: Panasonic UB820 UHD player  (Read 30499 times)
Re: Panasonic UB820 UHD player
« Reply #45 on: January 16, 2019, 23:07 »
A. A lot of recent movies on FHD BDs are region free
B. Who watches BD when got UHD and can get cheap player for region free
« Reply #46 on: January 17, 2019, 08:28 »
Buy UHD player to play FHD facepalm
« Reply #47 on: January 17, 2019, 08:37 »
for me is using separate FHD player to play regular BDs lah... UHD is like modern "mini laserdisc" where no region coding is a major concern.
However, different individuals hv different "ideological" setups. Some goes separate gears for different purpose, some looks for minimalistic setups.
« Reply #48 on: January 17, 2019, 09:04 »
Everything I play these days are UHD discs.
Or streaming.
FWIW I had a region B locked Oppo 203 before and playing a number of Region A discs I imported from Amazon and they all played fine. I think most companies relaxed the region coding towards the end.
Offline kikoman
  • Why so serious?
« Reply #49 on: January 17, 2019, 10:34 »
Same here DH. I fully agreed on your last few posts. After going into UHD, I never turn back to FHD.
Marantz AV8802A MM8003 MC207
Panasonic UB9000K Japan Limited
Pioneer LX800
Offline matix
« Reply #50 on: January 24, 2019, 11:31 »
Same here.  I have many FHD musicals and concerts which I won't double dip to get UHD.  Has anyone got a set from US?
« Reply #51 on: January 24, 2019, 22:42 »
I'm on the verge of placing an order from US. At this moment, Panasonic Singapore has not announcement on the UB-820 availability.
Offline Vinylfan
« Reply #52 on: January 26, 2019, 20:42 »
How does this compare with Panasonic 9000?
« Reply #53 on: February 10, 2019, 16:13 »
Bro Doggie, any "more" comments you like to make after using the UB820? especially the HDR Optimizer feature. Good, great?
« Last Edit: February 10, 2019, 16:14 by desray »
« Reply #54 on: March 28, 2019, 18:23 »
New firmware available. Finally hitting the Info panel button twice can bring up the metadata details on the media disc itself (previously only available in UB-9000)
https://av.jpn.support.panasonic.com/support/global/cs/bd/download/ub420/ub420_us.html
« Reply #55 on: March 28, 2019, 18:51 »
I’ve been using it at work with a Benq W1700. Gonna test it with the W2700 and W5700 next.
Definitely a lot of pop with the Benq W1700
« Reply #56 on: March 28, 2019, 19:38 »
Thanks for sharing. Never use it in your SONY VW760ES?
« Reply #57 on: March 28, 2019, 19:52 »
The main issue is that when I watch Netflix or Amazon Prime on the AppleTV, can’t use the HDR Optimizer. Maybe I’ll try the Panasonic app. But they were pretty dismal before.
I have been watching more of Amazon and Netflix.
« Reply #58 on: March 28, 2019, 20:01 »
Yes, both Youtube and the Netflix app will utilize the HDR Optimiser but I agreed with you that the built in apps is pretty dismal. I probably won't use it as well. LoL...Panasonic is like Pioneer, they don't really care about their user interface and their apps. If that is the case, they should be like Oppo - stick to what it does best - video and music...nothing else.
« Reply #59 on: March 28, 2019, 20:33 »
Is the Dolby Vision big still present on the built in apps?
