Author Topic: Panasonic UB820 UHD player  (Read 27001 times)
Re: Panasonic UB820 UHD player
« Reply #15 on: September 12, 2018, 00:14 »
From AVS
Quote from: jbrinegar;56790622
Here are my settings that I like to use:
UB820:  SDR2020, HDR optimizer on, slider to +2
885:  Laser at 80, D65, Gamma 2.4, BT2020,  tune brighness and contrast with masciola disc (For me with masciola i get brightness on 50, contrast on max)
Youll get nice bright images. The HDR optimizer on in the SDR2020 setting will tone map according to each disc metadata.  I think it works great.  Much better details in dark scenes, and no clipping in the extra bright scenes (I can finally see the minister of magics face in harry potter goblet of fire quidditch scene).   I just wish it had an HDMI input like oppo.
Will try it out tomorrow.
Offline denon2311
« Reply #16 on: September 12, 2018, 08:30 »
What is the DAC used? Is there any App will work with the player
« Reply #17 on: September 12, 2018, 08:34 »
I use it only as a Transport. It’s not going to replace my other audio transports.
« Reply #18 on: September 12, 2018, 17:45 »
Almost the same dimensions.
Rear missing dedicated stereo out and coax out.
New firmware is out already. Wasn’t there yesterday.
« Reply #19 on: September 12, 2018, 18:07 »
Holee crap
Just hooked the 820 to my ZD9, enabled Dolby Vision and set display to high luminance display.
Then plonked in Black Panther. So much shadow detail. I swear a lot of it was missing in the 900 before.
« Reply #20 on: September 12, 2018, 20:17 »
Holee crap
Nice!
« Reply #21 on: September 14, 2018, 19:25 »
Tonight I decided to take the Oppo 203 out of the projector set up and replaced it with the 820.
And I used this setting
“Here are my settings that I like to use:
Youll get nice bright images. The HDR optimizer on in the SDR2020 setting will tone map according to each disc metadata. I think it works great. Much better details in dark scenes, and no clipping in the extra bright scenes (I can finally see the minister of magics face in harry potter goblet of fire quidditch scene). I just wish it had an HDMI input like oppo.”
DAMN. After marveling at how good Black Panther looked on the ZD9 with Dolby Vision I had despaired at getting this title to work with projectors.
But with this new setting the terribly washed out scenes with the 760ES previously now look actually watchable.
« Reply #22 on: September 16, 2018, 06:18 »
Haizzz... Can see cannot buy...
https://www.videopro.com.au/p-11950-panasonic-dpub820gnk-ultra-hd-blu-ray-player.aspx
In few days time going to Melbourne liaoz... but Melbourne JBHiFi only carries UB420 nia...
« Reply #23 on: September 16, 2018, 07:36 »
binglee might have a few
Offline eggz
« Reply #24 on: September 21, 2018, 14:21 »
Holee crap
So this player supports the low latency DV profile that the Z9D requires? Sooooo tempting!
Offline dsj88
« Reply #25 on: September 24, 2018, 17:51 »
If anyone in QLD or can arrange shipping here. $478 using PHOME20 code.
https://www.ebay.com.au/itm/Panasonic-DPUB820GNK-Ultra-HD-Blu-Ray-Player/323463906161
« Last Edit: September 24, 2018, 17:55 by dsj88 »
Offline Vinylfan
« Reply #26 on: September 24, 2018, 18:21 »
Is it available in SG yet?
« Reply #27 on: November 12, 2018, 12:06 »
Offline FookLai
  • survivng with bare system
« Reply #28 on: November 14, 2018, 21:27 »
My pioneer bd 350 LCD screen just died. Going to need a uhd player which occasionally playing some Blu-ray gotten from JB. Anyone know if ub820 suffer from cineavia issue?
Sent from my CLT-AL01 using Tapatalk
« Reply #29 on: November 15, 2018, 13:25 »
Depending on where u brought from... It's locked to the specific region it is sold.
BluRay region hack can be possible every time u put a disc in and execute a small pause in process. DVD wise... So far... There wasn't any mention.
