Author Topic: Apple Event - new iPhones?  (Read 26809 times)
Re: Apple Event 12 Sept - new iPhones?
« Reply #271 on: December 28, 2018, 18:14 »
Finally caved.
Got the iPhone XS Max 512GB from Telstra. The 64GB X was running out of space every day. Deleting the tonnes of crap from my WhatsApp chats wasn’t enough.
It was on the unlimited plan so unlimited data and local and international calls which seems pretty cheap for $199 a month. For bundling my ADSL homeplan they even threw in an iPad 9.7” (Q1 2018 model) 32GB with 10GB data a month.
I think demand for the new models mustn’t be too high. Been in stock for a long time.
« Reply #274 on: August 24, 2019, 09:42 »
Better Face ID? Oh yes pleasssssse!
"There also appears to be a significant update to Face ID on the way. Bloomberg describes the new sensor hardware as ‘multi angle’:
The phones will include a new multi-angle Face ID sensor that captures a wider field of view so that users can unlock the handsets more easily – even when the devices are flat on a table...
Source: https://9to5mac.com/2019/08/22/bloomberg-apple-iphone-11-more/
« Reply #275 on: August 24, 2019, 10:58 »
 ;D... can't help yourself huh, still obsessed with iPhones  ;)
« Reply #276 on: August 24, 2019, 11:06 »
Bros
Can I ask for help
My iPhone XR running 12.4 notes app crashes all the time
Any remedies?
Thanks 🙏
« Reply #277 on: August 24, 2019, 11:27 »
Bros
Can I ask for help
Any remedies?
Thanks 🙏
Have you tried Googling? Seems there's a bunch of reports and recommendations on fixes.
« Reply #278 on: August 24, 2019, 11:38 »
;D ... can't help yourself huh, still obsessed with iPhones ;)
Huh, OMG, that's "silly" of you to think that way? How many times do I need to repeat and explain myself...I'm not an Apple fan...I'm brand-agnostic. I'm using both Android and iOS at the same time with ease...Using an Apple device DOES NOT automatically makes you an Apple fanoboi (or obsessed one at that)...using it simply because of an App that works better on iOS than Android (for stability) and it is for work use.
This is not an"either-or" thing when it comes to choice of using a smart phones these days...I can't believe how "narrow-thinking" you are when it comes to this?  ???
« Last Edit: August 24, 2019, 11:40 by desray »
« Reply #279 on: August 24, 2019, 11:42 »
Bros
Can I ask for help
Any remedies?
Thanks 🙏
How so? Describe the exact problem that you face...like the App open and then close or .....???? I don't experience that on my iPhone X Max on iOS 12.4.
« Reply #280 on: August 24, 2019, 11:45 »
It's odd. My 7 plus doesn't have the issue.
I press on the app, the notepad app, it opens then closes immediately. But I have to still swipe it to shut the app when I'm closing other apps. Just that it crashes...
Google?
I've seen some people suggest deleting it and re-installing... but that may mean losing the notes / reviews I've typed... and I'm a PC idiot, that's why I'm on a Mac..
« Reply #281 on: August 24, 2019, 11:57 »
Google?
Yes, my next suggestion is to delete the app and re-install it. Ensure that you have enabled the iCloud for backup first to save the notes before you delete the app. I can't think of any better suggestion/solution to this issue since it cannot be replicated. Imo, something just screwed up during the iOS OTA update. Usually deletion and re-installation of the app will solve it.
« Reply #282 on: August 24, 2019, 17:44 »
Huh, OMG, that's "silly" of you to think that way? ...
Offline sigurros
  • "What we think, we become"
« Reply #283 on: August 24, 2019, 20:45 »
Bros
Can I ask for help
Any remedies?
Thanks 🙏
Download iOS 13 beta 7.
Smooth enough for daily driver.
« Last Edit: August 24, 2019, 20:46 by sigurros »
« Reply #284 on: August 25, 2019, 08:12 »
I'm going to make this terse...my humble advice to you is, if you have nothing constructive to offer...then I suggest you keep those snide remarks to yourself...it'll only make people annoyed at you.
