Author Topic: Recommended Viewing Distant for RPTV  (Read 3477 times)
Offline patriot75
  • DoDo Boyz
« on: May 07, 2002, 13:25 »
Hi guy just want to find out the recommended distant from my RPTV to my Sofa. Presently set at about 2 m but thinks very near. Thanks for yr help.
duckling
Re:Recommended Viewing Distant for RPTV
« Reply #1 on: May 07, 2002, 16:36 »
Shld be 3.5 meter and above....but that depends on individual eye sight.
Offline Corona11
  • Never take a Windtalker seriously.......
« Reply #2 on: May 07, 2002, 17:01 »
2 m sounds a bit close, do you get eyestrain?
Offline cracker
« Reply #3 on: May 07, 2002, 22:34 »
the guideline is abt 2.5 times the diagonal distance..
so for a 43" RPTV...min distance should be abt 2.5m away
"....U may say I'm a dreamer......
     But I'm not the only one....."
                                             JWL (1940-1980)
Offline cracker
« Reply #4 on: May 07, 2002, 22:36 »
                                             JWL (1940-1980)
Offline patriot75
  • DoDo Boyz
« Reply #5 on: May 08, 2002, 10:12 »
thanks guy for yr valuable time and information. Will shift my sofa to 2.5 m away form my 43" TV. Thanks
Offline xpert1974
  • I love YaBB 1 Gold!
« Reply #6 on: May 08, 2002, 22:43 »
The further you sit the better. 2m is CONFIRM too close. I am having it at abt 2.5-3m away. I feel its only acceptable. I feel better sitting abt 3.5m away...but no space :)
Offline Vijay
    • Vijay's HTS
« Reply #7 on: May 20, 2002, 23:51 »
3m is a good compromise.
I'm 3m apart from my 47" widescreen RPTV.
I don't sit with the TV often, only for some good movies. So it's okay for me. But seriously for prolonged viewing, I think I would be happier to shift it to 3.5 or 4m  but parents want the sofa to be at the 3m mark :P
But 3M is safe.
Vijay Anand
Hardware Zone Reviewer & Senior Forum Moderator
http://www.HardwareZone.com/
Offline InnocentBlood
« Reply #8 on: May 21, 2002, 10:20 »
what RPTV are you using ?
Sex N' Violence
Undesirable Publications
Offline patriot75
  • DoDo Boyz
« Reply #9 on: May 21, 2002, 21:45 »
I shifted to 3.3m and wonderful.
But 3M is safe.
duckling
« Reply #10 on: May 21, 2002, 23:05 »
Glad that you've got it right!! Enjoy!! ;D
