Thanks for your reply. I agreed HPDA is slightly on the warm side. So considering upgrading.
For me, the ex-m1 is a relatively neutral sounding amp with a tinge of musicality and smoothness. There's little to no warmness, hence to get a bit more organic richness and lush tones, I decided to pair it with the s55n. Previously tried other more neutral sounding cables on it, and also the Furutech DPS4.1, but I think they work better in other chains in my setup than on the ex-m1. S55N is what I'd call a 'tuning cable', and if you wire your whole setup with that, the warmness may be too overpowering imo.
I fully agree that fuses do affect sq but to me, it has never brought about a performance jump by a few levels. Maybe his levels are really close together hence the huge jump Despite that, I'm using telos and audio magic fuses for my kinki dac/amp and there is a definite improvement over the stock, though I wouldn't rate it as jumping a few levels..
Hi Benlzy,Thanks for the tip. Kinki is really good amp but just abit dry on the vocal. I got a Plixir BAC which help to warm Kinki more.Do you use a power conditioner too? What power cord do you use from wall to power conditioner since Furutech S55N is already 10awg?I am considering to change power cords from wall to conditioner and conditioner to amp.Which Audio Magic fuse model to match with Furutech S55N?
Sorry slight modification to my post. I tried the 6700, not the 7500. Mistook the series. I could always bring the virtuoso over for you to try if you want to since that's to me quite neutral with good high extension, might fit what you're after.
Previously the EX-M1 was $2898, not too sure about the current prices - best if you check directly with Alvin.
No Prob. So which you think is a good upgrade from HPDA? Thanks for your offer. Currently running in the plixir Elite conditioner with the upgraded receptacles. Once settled down, will arrange for a listen to virtuoso.
If you're liking a neutral, excellent high extension and tight bass but quiet and dynamic cord, the 6700 might be the one for you. But it's pricey, about S$2.5k.Virtuoso Ultra is also neutral, there's more excitement in the tone, more expressive, though the highs are not as refined as the acrolink. More flexible though, and new was around US$1250. Can source for second hand ones.The cardas clear was also neutral, but the bass extension and slam was quite more apparent than either of those cords. Overall very open soundstage and good vfm if you manage to find second hand, which is around S$750
My Kinki B7 mono blockas have already clocked 120hours, its' getting better and better.The overall performance is achieving 90 percent of my Karan amp has and the low and attack is even better than Karan. I am enjoying the music coming out from these gems, compact and powerful, most important very musical.
The EX-M1+ is the one with HT Bypass. I'm using the ex-m1 in a 2.1 stereo setup - you're welcomed to give it a listen just to have a feel of the kinki sound. Just pm me if you're interested.After months of listening, I still find the ex-m1 performs better in high gain, an issue for me because my speakers are quite sensitive and any volume past "4" is bordering loud.. haha. Can't finely adjust the volume if using in high gain :/
