Author Topic: Where to get Benq W7000 replacement bulb?  (Read 1004 times)
Offline keai
« on: May 11, 2018, 23:51 »
My beloved Benq W7000 is dying, bulb life almost hit 4000 hours, tonight watch movie half way, dim till almost black, cant watch. seems bulb needs replacement. Have been eyeing for 4k projector for a couple of months but have yet decided which model to get. If W7000 bulb can still be easily replaced locally at a reasonable cost, i would prefer reviving it to last a little longer till i get my hands on a 4k pj.
Would appreciate if fellow forum bros can advise where i could get my W7000 bulb replaced, and estimated cost, many thanks!
Offline keai
Re: Where to get Benq W7000 replacement bulb?
« Reply #1 on: May 12, 2018, 12:45 »
this morning watched 2 hour plus, no issue, but dont know how long it can hold on,
Offline bobby
« Reply #2 on: June 05, 2019, 23:45 »
Hi, Keai did you find the Benq W7000 bulb replacement? I also faced a problem similar to my projector. I want to replace my projector with BENQ MS524AE. Besides its affordable price, it also seems reliable as per the information I read at https://passtools.com/best-projectors-under-300/#3_BenQ_MS524AE_SVGA_Recommended_Business_Projector_Under_300
But before replacing it with a new one, I want to try fixing it first. Need your info thanks
« Last Edit: June 05, 2019, 23:47 by bobby »
Offline keai
« Reply #3 on: June 06, 2019, 11:07 »
Hi Bro, the bulb replacement service is available here in Benq engaged repair company, total cost around S$420 and takes about 2 weeks to get the bulb from Taiwan if I remember correctly. You can give them a call for more details:
City : Singapore
Shop Name : CSE Pte Ltd
Products : Digital Signage / Large Display / LCD Monitors / Projectors / ZOWIE e-Sports
Address : 30 Marsiling Industrial Estate Road 5, #03-01, Singapore 739211
Phone : +65 6362 1202
Fax : +65 6265 0524
Contact Person : Aisha Binte Hashim
Office Hour : 08:00~17:00
Sent from my CLT-L29 using Tapatalk
Offline bobby
« Reply #4 on: June 06, 2019, 12:03 »
Okey thanks a lot bro for the information
