Author Topic: How to recover photos from corrupted SD cards?  (Read 5397 times)
Offline bluepill193
« on: May 07, 2018, 01:29 »
Hi bros, my microSD card died and I lost >1 year's worth of photos of my kids...Irony is that it died while I was trying to backup to my Macbook.
I am willing to pay for data recovery, can you tell me where to go? Don't want to try DIY free software kind of fixes in case I screw it up further. Thanks for your help!
Offline fei
Re: How to recover photos from corrupted SD cards?
« Reply #1 on: May 07, 2018, 08:13 »
Incase useful, I previously used http://www.greenergy.com.sg  to recover a HDD, thankfully was successful. Not sure if they can handle SD though? Can explore if can help you?
*Note: Am not affiliated nor working for them, sharing incase helpful for fellow XPians
Offline bluepill193
« Reply #2 on: May 07, 2018, 08:19 »
Thanks! Will check it out
Offline stereoman2
« Reply #3 on: May 07, 2018, 09:26 »
Before going to those 3rd parties, try using recovery software available as they READ from the souce and write to other destinations.
Many are FOC to try eg trial. I have done so in the past for friends with acceptabe success.
For instance https://www.howtogeek.com/232931/how-to-recover-images-off-a-corrupted-sd-card/ and https://www.easeus.com/data-recovery/card-recovery-software/sd-card-recovery-freeware.htm
« Last Edit: May 07, 2018, 09:33 by stereoman2 »
Offline bluepill193
« Reply #4 on: May 07, 2018, 12:31 »
Tried the Transcend RecoveRx, but it does not allow me to select the SD card for diagnostics.  Will try those you suggested, thank you
Offline stereoman2
« Reply #5 on: September 26, 2018, 07:37 »
Any success with the above?
