Author Topic: New CDP or used CDP?  (Read 4929 times)
Offline sky
« on: May 05, 2002, 23:46 »
Hi.  I wanna get some advise from the gurus here.  I have a budget of $1300 for a CD Player.  Should I get a new one or get a good high-end but second hand of about $1000?  Somehow, I think CD payers should get a new one as technology is always on the move.  Moreover, there is this HDCD, DVD-audio, SACD formats available.  Hmm...if you were in my shoes, what would you get?  If get new ones, got any recommendations?  Heard that Exposure CDP is good.
Thanks  ;D
Offline hw
Re:New CDP or used CDP?
« Reply #1 on: May 05, 2002, 23:48 »
the only concern would be the age.. older CDP tends to have faster laser pick-up failure.
how old is "old"? i'd put it around... 5 yrs?
juz my personal views.
Offline sky
« Reply #2 on: May 05, 2002, 23:53 »
Yeah, I guess 'old' means not more than 4 years old.  Scared if buy an 'old' one and then it gets spolit within a year, I will 'bang' one.   :o
Offline dgps
  • yawn!!
« Reply #3 on: May 05, 2002, 23:58 »
ermmm....for 1.3k u can get new Exposure 2010 CDP liao lor.............
Thanks  ;D
duckling
« Reply #4 on: May 06, 2002, 03:12 »
$150 more can get Rega Planet 2000 or $850 get Rotel 1070. ;)
Offline aloychan
  • Always a Master & an Apprentice, no more no less.
« Reply #5 on: May 06, 2002, 08:46 »
I would go for the Rotel RCD-1070. Given the fantasics sound at a low low price. The built looks very solid and heavy too. Have audit the 1070, treble warm bass tight.
Exposure not too bad, but I would go for the 1070 with a pair of good interconnects.
I recently bought a 2nd Hand Cyrus dCD3 Q24 with external power supply. It's abt 1.5 yrs old with burr-brown 24bit DAC. Cost me S$1.2k, and loving it every minute.
Just my 2Cents.
