Author Topic: Powerline cables from mcb to wall outlet  (Read 3192 times)
Offline francishuang
Shindo is Music
Offline Tiktokape
Re: Powerline cables from mcb to wall outlet
« Reply #16 on: April 12, 2018, 10:59 »
Thanx boss
I should be ordering the 4030anniversary.
Good choice, need patience to trim and terminate it. I’m using it from wall to conditioner
« Reply #17 on: April 12, 2018, 11:03 »
Haha...
Using 4030a which is multi strand for 2 lines
Noa Looking at a solid core type for 3rd line
Shindo is Music
Offline Tiktokape
« Reply #18 on: April 12, 2018, 11:17 »
But I wonder how you route it internally in wall on 4030A.
Kiek
« Reply #19 on: April 12, 2018, 11:28 »
Thanx boss
bro, only 15A.
« Reply #20 on: April 12, 2018, 12:07 »
4inch trunking boss
Will be rebuilding the walls. So everyhing will just hide inside. Mcb to wall side is false ceiling. Then go down the internal wall thru 4inch trunking
Shindo is Music
« Reply #21 on: April 12, 2018, 12:08 »
Boss, rated 50A. Not tetminating it power cord plugs
bro, only 15A.
Shindo is Music
Offline annapurna
« Reply #22 on: April 12, 2018, 13:01 »
You should also consider Furutech DPS4.
SME20/12 V12 arm, Clearaudio Titanium V2, Pass XP27 Phono, Marantz SA10, CD7, NA11S1, Pass XP22 Pre, XA100.8 Monos, Sonus Faber Lilium, Kimber PK10 Palladian, Shunyata Alpha Zitron & Yter PC, Yter XLR, bi-wire spkr cables, Nordost Tyr phono cables, PurePower PP+ 3000  Regenerator, TAOC ASR2, Furutech GTX-D NCF(R)
Offline jerome_the_lang
« Reply #23 on: April 12, 2018, 13:46 »
the furutech DPS4 has been touted to be less sensitive to directional changes.
maker say got align the copper crystal grain structure to reducing crystal grain boundaries wan.
meaning wat i also dunno, but they say make it less sensitive to directionality liao.
anybody got test before?
« Last Edit: April 12, 2018, 13:49 by jerome_the_lang »
Main System:
Sources: EMM Labs TSDX / DAC2X v2
Amplifiers: Sony TA-E1, TA-N1
Speakers: Sony SS-M9ED
Cables: Straightwire Crescendo and Serenade interconnects, Straightwire Serenade double run speaker cables
2nd System:
Sources: ELP Laser Turntable, Project RPM9.1x with Otofon 2M Bronze, Pass Labs Aleph Ono
Amplifiers: Pass Labs XP20, X350
Cables: Pro-Ject RCA CC Phono cable, Straightwire Crescendo interconnects, Straightwire Crescendo double run speaker cables
Offline Tiktokape
« Reply #24 on: April 12, 2018, 13:57 »
4inch trunking boss
Looking forward to hear them soon! Have fun!
« Reply #25 on: April 12, 2018, 14:01 »
I'll be a bit hesitant buying a 3-in-1 type power cable. Because how can we be sure how well the cable maker can control the manufacturing process for each of the 3 conductor strands, the weaved shield, the individual dielectric jackets and the outer dielectric jackets to adhere to the parameters affecting directionality?
Even furutech acknowledges that directionality for ac power is important. Although they said their latest cables are less sensitive to directional changes, how can we be 100% sure what they said is true?
 ;D
Previously, my friend (nick:Powerman) gave me 3 strand of wires, about 10meters long. I cut 5m for testing directionality. Terminate them to feed a power extension board.
I tested each strand of cable one by one (terminate, test, change one wire direction only, reterminate, test again,...)
Quite easy to hear difference for each individual strand, and their synergistic total effect.
So now, since i'm helping friends setting up their power supply, I've included in the tender specs for contractors to provide us 2 meter sample cables for checking directionality prior to installations. My friend not going for audiophile standards, Just HDB approved ones. But it should be fun doing the comparisons again...
 ;D
« Last Edit: April 12, 2018, 15:31 by jerome_the_lang »
Main System:
2nd System:
Offline joamonte
  • audiophile
« Reply #26 on: April 15, 2018, 13:07 »
Haha...
Last year Singapore hifi show, the guy on right side say it is better to use one set of power wire to hifi power socket rather than multi line, because different set of wire and wall socket will have different ground impedance , it will cause noise when different components in your system have different ground reference point, he said all components in hifi system power should use only one common power point...  ::)
https://youtu.be/nv88BNHofds
« Last Edit: April 15, 2018, 13:53 by joamonte »
« Reply #27 on: April 15, 2018, 16:31 »
In a way hes correct, hes trying to find common artificial ground. They way he is proposing will help with it to some extend. I am using sound affairs pixilr balance pre cond each for the 2 main lines. But what i am more concern abt is finding a common dc ground reference.
« Last Edit: April 15, 2018, 16:48 by francishuang »
Shindo is Music
« Reply #28 on: April 15, 2018, 16:49 »
I cut some and pass u to try?
 ;D
 ;D
Shindo is Music
« Reply #29 on: April 15, 2018, 20:05 »
ok, can.
Main System:
2nd System:
