Author Topic: DVD player <SHINCO 8700 Best Buy>  (Read 12504 times)
Offline Tripp
Re:DVD player <SHINCO 8700 Best Buy>
« Reply #30 on: May 08, 2002, 07:54 »
It really depends on what kind of connections you want equipped for your Progressive Scan DVD Player.
- Skyworth 1050P, 1050D, Nintaus 9769 (HDCD for 9769, DCDi chipset, with VGA out)
- Philips Q50, 962SA (SACD for 962SA, DCDi chipset, no VGA out)
- Samsung P708 (DCDi chipset, no VGA out, avail in HK only)
- Shinco 8700 (HDCD, Zoran chipset, with VGA out)
- Toshiba 5300A (HDCD, DVD-Audio, Zoran chipset, no VGA out)
Of cos', getting PAL progressive signals from the players is a definite plus. But as mentioned, your Progressive TV may need to support this type of signal. No problems if connected to plasma or projectors.
« Last Edit: May 08, 2002, 07:56 by Tripp »
Offline variablefeedback
  • Boom! Boom! Boom! Boom! Boom! Boom! (THX)
« Reply #31 on: May 08, 2002, 17:55 »
hi shi fu tripp,
thanks for showing my wantlist chart graphically. I CAN SEE CLEARLY NOW.
My Seller's Pledge:
1) I do not entertain buyer's remorse.
2) I will never sell any known faulty items on the internet without informing in the advert.
If buyer is uneasy about buying used items from the net, then buy a used one with some warranty life left or new one from the store.
I believe that it is unethical to sell something that is faulty (but seller do have their limitations) in any forum and claim that it is 100% OK because I am a buyer myself.
Offline DizzyD
  • I am a HTphile !
« Reply #32 on: May 13, 2002, 11:02 »
Does the Shinco 8700 has a DTS/DD decoder built in ? I have a 5.1 input on my ancient Denon.
DD
Offline queks
  • XtremePlace.Com Forever!
    • XtremePlace
« Reply #33 on: May 13, 2002, 11:15 »
Yes. i tested the shinco with my sony PROLOGIC amp using 5.1 input c'os no coax or optical connection. Sound OK for HT but bad for music. Sound muddy.
*** XtremePlace ! Don't leave home without it ! ***
