Author Topic: MultEQ Editor: App for Denon & Marantz AVR and AV Amps  (Read 3837 times)
Offline kaydee6
Re: MultEQ Editor: App for Denon & Marantz AVR and AV Amps
« Reply #15 on: June 22, 2019, 15:42 »
iOS version is smooth and stable. Can’t say the same for the android.
« Reply #16 on: June 22, 2019, 16:03 »
You owned the app on both platforms? Wow...
Offline kaydee6
« Reply #17 on: June 22, 2019, 17:04 »
No I don’t. But I see most of the issues at avsforum is on the android version. I’ve never encountered any issues on my iphone.
« Reply #18 on: June 22, 2019, 17:06 »
I see.
Offline kaydee6
« Reply #19 on: August 06, 2019, 12:07 »
1.4.3 is out today. Crossover change not sticking bug resolved.
« Reply #20 on: August 06, 2019, 12:38 »
Finally. Arghh.  It sure took them long enough to fix it.
« Last Edit: August 06, 2019, 12:40 by desray »
« Reply #21 on: August 06, 2019, 12:50 »
Hooray! I have tried the app on my iPhone and the cross over setting sticks even after I changed them. Previously, the front channels will go back to 40Hz.
« Last Edit: August 06, 2019, 13:16 by rayleh »
Offline kaydee6
« Reply #22 on: August 06, 2019, 13:28 »
Looks like you are the only review on the app. :)
« Reply #23 on: August 06, 2019, 13:30 »
Haha. I certainly hope not. But I do give a 3 stars for the bug though.
« Reply #24 on: August 06, 2019, 13:40 »
Yep. That’s the bug we are talking about.
« Reply #25 on: December 08, 2019, 13:06 »
For those using the Audyssey MultEQ Pro Editor, this is an awesome complement tool to help you get more precise readings of the frequency response and its corresponding SPL which otherwise is inacessible. You can also input a more precise Max EQ range. More importantly, you can have more control over the boost/cut at a specific frequency range.
Here is where you can download it: https://github.com/ratbuddy/ratbuddyssey/releases/tag/v0.2.1
Offline sijusid
« Reply #26 on: December 16, 2019, 13:55 »
Thanks...will check it out.
Personally, i have been using the app on my android phone, and never faced any major issue, other than not finding my avr in between measurents (happened only twice).
Also patiently awaiting on your guide on setting house curve on audyssey app.
« Reply #27 on: December 17, 2019, 20:43 »
Yes, I will try to release the guide later this week...Busy of late.
« Reply #28 on: December 17, 2019, 22:05 »
Hi Desray, looking forward to your guide too. Thanks in advance.
Offline wcseow
« Reply #29 on: December 24, 2019, 12:33 »
For those who intend to purchase the App, be informed that you will need to pay for the same app on two different platforms - Android and iOS. So before you commit, make sure you know which platform you intend to use the app for. I'm using iOS version which many consider more stable compared to the Android brethren...
Hi. If i have multiple Denon AVRs, do I need to purchase one app for each AVR?
Sorry, I cant seem to find any references on this on the net.
« Last Edit: December 24, 2019, 12:36 by wcseow »
