Author Topic: Zappiti one 4k hdr media player  (Read 35349 times)
Re: Zappiti one 4k hdr media player
« Reply #300 on: February 11, 2020, 22:56 »
thanks for the detailed reply i do intend to stream from my NAS but it is good to know of the further capabilities of the Zappiti should I ever need to pop in a SATA drive inside of it. i like the idea of using a docking station but would such a device be limited to drives which are 3TB and below? the ones being sold on Zappiti's site can only read a maximum of 3TB. which kind of defeats the purpose when the player itself can handle up to 16TB per drive.
I’m not sure about your movie viewing experience but for me, I rarely run out of hard drive capacity because I usually remove a few older titles when I upload newer titles.
Don’t be tempted by this >16TB support etc etc. To me, the bigger capacity may not necessary be a good thing if the drive becomes corrupted at some point. Imagine doing a scandisk function to repair some common drive errors will take forever for such a huge capacity. IMO a 6TB hard drive is the max I will go at any one time. If you require more, just purchase another 6TB drive to top up.
I usually stream normal Blu-ray 1080p rip and store it in my NAS and stream it to my media player. For higher bitrate and file size like say a BD ISO files (full rip), I will stick with external HDD like using a docking station or even a portable USB drive to take advantage of the USB 3.0 speed.
Offline jonchew
  • http://www.jjbizwebsite.com
    • http://www.jjbizwebsite.com/cbsearch/search.php
« Reply #301 on: March 15, 2020, 10:04 »
Hi. I am looking for the media player to ripping my old DVD instead of keeping so many disc at home due to space constraint . Before I planning to get Zappiti media player, may I know is the Zappiti require any additional software for ripping Blu-rays or Dvd?
Another question is whow to ripping BR or Dvd into the Zappiti media player?  Or I need to plug in an external dvd driver via USB 2 and 3.0 ports to ripp it to the player ? Thanks.
P.S I never buy any media play before, so this is the first time and consider to get one for ripping Dvd or BR.
« Last Edit: March 15, 2020, 10:17 by jonchew »
Most of what we learn we learn from living
« Reply #302 on: March 15, 2020, 10:35 »
You are looking at the wrong place...If you want a solution on ripping bluray/dvd/cd to NAS, there are other s/w like MakeMKV and AnyDVD HD from RedFox to do it but that's a whole different topic altogether. If money is not a concern for you, Zappiti has this NAS Rip including ripping of 4K physical disc and cost a lot (about S$4.2K+). For details: https://zappiti.com/zappiti-nas-rip-4k-hdr.html
« Last Edit: March 15, 2020, 10:38 by desray »
Offline jonchew
« Reply #303 on: March 15, 2020, 10:54 »
Hi.
Hi. Bro Desray. Can I ripping the movies to my PC HD and use the HD to the Zappiti media player? Thanks.
Offline Tiktokape
« Reply #304 on: March 15, 2020, 11:14 »
Zappiti supports internal or external drives so long it is formatted to the compatible file system. In fact, no need to even move the hard disk, so long the computer and media player are connected to the same network, can playback as well.
Offline jonchew
« Reply #305 on: March 15, 2020, 11:21 »
Hi. You mean I can ripping all the movies to PC HD using my AnyDVD HD software and move the HD to Zappiti and playback?
« Reply #306 on: March 15, 2020, 11:22 »
Hi. Hi. Bro Desray. Can I ripping the movies to my PC HD and use the HD to the Zappiti media player? Thanks.
No need to do that...simply rip the movies and then transfer the content to say an external HDD or you can transfer to a NAS for direct streaming. Zappiti media player supports BDMV/DVD ISO file structure for playback.
Offline Tiktokape
« Reply #307 on: March 15, 2020, 11:27 »
You can rip the movies using your computer. Store them in your internal hard disk in your computer. Playback via the movies via the media player so long your computer remains powered on and both the computer and media player are connected to the same network. The media player can access the hard drive via SMB.
Of cause you can rip all the movies into a hard disk that is connected internally or externally. Internally meaning via data connection. Externally meaning via USB/eSata etc.
Once you are done with it; add the hard disk internally or connect the hard disk externally to media player. The question is if you have only one hard disk in your computer, you can’t move that to media player.
Offline wcseow
« Reply #308 on: March 15, 2020, 14:47 »
Hi desray
Seems like this is viable for me since I will need to buy a NAS and a PC which i guess will be roughly the same price and remove the hassle of using a PC. After reading the materials, i have some questions which i hope u could advise.
a. Must the media player be a Zappiti?
b. Is the built in BD drive region locked, I have Region A and B bds
c. Is that model available in Singapore?
« Reply #309 on: March 15, 2020, 14:55 »
Hi desray
Take note, I have not used this Ripping NAS from Zappiti before. But if you asked me, I’ll venture a guess:
a. Must the media player be a Zappiti? - Not necessary UNLESS Zappiti has some restrictions on their custom Ripping NAS which prevents normal media player that utilise SMB or NFS protocol to communicate with the NAS.
b. Is the built in BD drive region locked, I have Region A and B bds - Good question. No idea. But ripping 4K UHD physical disc is likely possible without any need to bypass some form of AACS since it is region free. For DVD and CD rips, it should be fairly easy. The only problem I can foresee is the Blu-ray Discs which comes with Cinavia watermarks etc. Nevertheless you can drop them an email or fill up the contact form in their website and they will respond to you. One thing good about Zappiti support as opposed to MIC media players like Zidoo or Egreat, the french really respond to customer inquiries. But be specific in what you intend to ask. After all, English is not their main language but in the few dealings with them, they understand Singaporeans quite well. LoL.
c. Is that model available in Singapore? - Nope. Order from Zappiti own website is the best imo. In fact none of their products sold locally in Singapore. There is no local distributor AFAIK but they do ship to Singapore. That’s how I got mine.
« Last Edit: March 15, 2020, 15:01 by desray »
Offline wcseow
« Reply #310 on: March 15, 2020, 15:53 »
Thanks desray
Will check with them
Offline InnocentBlood
« Reply #311 on: March 15, 2020, 17:46 »
I too am interested to know more about the Zappiti NAS. I think it will pair well with my Zappiti Audiocom edition.
Sex N' Violence
Undesirable Publications
Offline nur_hsc
« Reply #312 on: March 16, 2020, 11:58 »
Why dont just download fm website instead rip blu ray. Save yrouble n money. Just saying.
Zappiti Video v.4.23.251
« Reply #313 on: March 28, 2020, 16:40 »
The new version of Zappiti Video is now available. Please find here below the new features and improvements.
Zappiti Video
Changes in version 4.23.251
News:
Zappiti Quizz: A Movie-theme inspired quizz
Zappiti Service: new interface to control and update the different versions of Zappiti applications.
Improvements:
  • The search for extras is more efficient.
    Reduced loading time for launching videos with Source Direct (Direct Output).
    Visual improvement of the display of audio languages and subtitles in the synopsis page.
    Added icons for release date and duration on the synopsys page (classic theme only).
    Dynamic enlargement of the synopsis text when no audio language or subtitle is displayed.
    Improved error messages when trying to register
    Improvement of the layout of actors and directors in the synopsis page.
    Adding of a verification code sent by email during registration to allow the reset of the password if necessary.
Corrections:
  • Fixed an issue that prevented video playback from starting when Direct Output mode was enabled.
    Fixed an issue with caption uploading that could occur for some languages.
    Correction of trailers that no longer launched.
    Fixed a group issue that could sometimes be created as a duplicate.
    Correction of technical informations that sometimes went out of the synopsis page.
    Nas Synology: Zappiti Server sometimes wrote its files in the system section.
    Notarization of Mac applications
    Correction of the update process that no longer worked.
    Correction of the message which indicated the disc to be connected and which no longer appeared.
Sex N' Violence
Zappiti Firmware v3.15 now available in official release
« Reply #314 on: April 03, 2020, 10:28 »
Changes since the version 3.13:
New features
- 12-bit support (only in YCbCr 444 and 420).
- General picture improvements.
- Grain from the home page wallpaper has been removed
- The home page is now in French (requires choosing French in Android Settings), as well as other languages (English, German, Spanish, Russian).
- Ability to select the video player of your choice for streaming applications (“Nuplayer” or “Native Player”).
- The home page now supports screens with a display ratio of 2.35: 1
- New picture setting such as: Contrast, Brightness, Saturation and Hue.
- Hard disk standby mode.
- Adding a new version of Zappiti Service with Zappiti app management window.
Improvements
- Improved interface display performance.
- Global performance improvements.
- 23.976p fluidity and smoothness has been improved (be aware that video lag and glitches may still occur when using the following codecs: VC-1 and AVC-H.264 High @ L4 / 4.0).
- Improved SMB server and added SMB 2.0 compatibility.
- Improvement of the various information displayed in the “movie display window” screen while playing, in particular the indication of the bitrate and 2.35:1 aspect ratio support.
- Subtitles are now disabled by default (OFF).
- When resuming playback of a file, the last subtitle track is now used instead of the default subtitles.
- Improved support for default subtitles - Warning! The default subtitles do not work on certain files such as M2TS.
- Zappiti Service has been updated, you now have the possibility to choose a frequency of 23.976 Hz to avoid the black screen when launching a film. It also features an improvement of Direct Output mode.
- The Color Depth and Color Space settings are now accessible directly from the "Display" settings panel (previously accessible from Developer Options).
Fixes
- Fixed an issue where info could no longer be displayed when pressing the OK button on the remote control.
- Fixed an issue that prevented the second hard drive of the player to be seen from other devices on the same network (Zappiti Duo 4K HDR / Pro 4K HDR / Pro 4K HDR Audiocom)
- Removed the “DP Same as source” option from the developer options in the settings which could cause display issues.
- Correction of the French translation about the message indicating the change in resolution and frequency.
- Removal of the Screenlock option which could require reinstalling the firmware.
- Removal of the HDMI Rx option.
- Removal of the YouTube application which no longer worked (a functional new 4K version is available via MyApps / AptoideTV).
More info:
http://www.zappiti.com/zappiti_player_firmwares.html#hdrusb
Sex N' Violence
