Author Topic: Zappiti one 4k hdr media player  (Read 33242 times)
Offline bluepill193
Re: Zappiti one 4k hdr media player
« Reply #255 on: August 14, 2019, 07:46 »
"I have some Planet Earth II rips using MakeMKV with 1:1 rips and I have a hard time differentiating the PQ between a ripped version and a disc version. The difference if any is almost negligible especially if the display (OLED TV or Projector) is the one doing the upscaling and video processing work from the content itself. "
Desray, I read your reply in the thread on 4k disc vs streaming.
Between the zappiti, LG Oled tv (E6), and marantz SR7010 AVR, is the tv still the best for doing the video processing and up scaling? Given that the the avr and tv are both older models...
Thanks in advance for your reply!
« Reply #256 on: August 31, 2019, 20:53 »
Just tested the zappiti, must says it’s got the best picture quality I’ve seen so far for media player, very good indeed. Plays bdmv and HDR10 great even though the tv is non HDR
Text is crisp and sharp, good media player. Interface a bit cumbersome , but video is good !!
« Reply #257 on: August 31, 2019, 21:46 »
Glad you like it...
Offline FookLai
  • survivng with bare system
« Reply #258 on: September 01, 2019, 09:51 »
Absolutely agreed if you looking for best picture quality from media player then look no further. Of course the price is well reflected on the performance too.
Offline Tiktokape
« Reply #259 on: September 14, 2019, 14:13 »
http://xx3sv.mjt.lu/nl2/xx3sv/5y6xs.html
« Reply #260 on: September 14, 2019, 18:51 »
Redundant feature to say the least. Serious calibration should always do it on the display itself rather than the player. But it’s good to see the collaboration between ISF and Zappiti.
Offline Tiktokape
« Reply #261 on: September 14, 2019, 18:56 »
Can sell at higher price?
« Reply #262 on: September 14, 2019, 18:59 »
Zappiti strength lies with its superior upscaling algorithm compared to other MIC media players like Zidoo and Egreat. ISF certification will help to propel its marketing efforts to push its superior 2K/4K imagery. I’ll say it is a wise move by the french. Knowing their product strength and capitalise on it.
Offline jeffong
  • You'll Never Walk Alone
« Reply #263 on: September 22, 2019, 19:13 »
Has anyone tried the Infuse Pro 6 UHD-ISO playback on the Apple TV 4K?  How the playback quality compared to the Zappiti?
HDR Rulez - Panny UB820 | Oppo UDP-203 | Zapitti One Mini | Apple TV 4K
Stewart Firehawk 92" | LG 65E6T | Panny 65VT30 | Benq 5700
Denon 8500 | Denon 7200WA | SVS PC-12+ | JL E110
Offline Pismo Mac
« Reply #264 on: September 22, 2019, 21:08 »
IIRC Infuse does not allow Atmos or DTS X pass through.
Offline e24djenggos
« Reply #265 on: September 22, 2019, 22:05 »
Just enjoy the PQ much nicer when I bump it up with LPS.
Bro was wondering if 9v 1.8a ifi power can work. If not, please recommend the lps u use.
Offline Tiktokape
« Reply #266 on: September 22, 2019, 22:46 »
You can try whether iFi works in your case. If it does not power down means it probably works after a period of usage, you are good to go though I prefer to stick to the recommenced voltage, higher A is fine. If you have fitted a hdd in the media player, chances could be on the low side for iFi.
I have tried a couple of LPS; Jay Audio, Sound Affairs Elementa & Elite, Teddy Pardo & Sotm SPS-500, they are 12v with minimum 2A. Any of them will yield a better picture quality so I leave you to decide based on your budget. I do have iFi 12v but it not with me now so I can’t comment if it works.
The differences between them are mainly in the type of sounding and I prefer to take that out of context and discussion re the quality of sound as not all may agree with me. I have the luxury to try due to my music system. Have fun!
Offline comfortablynumb
« Reply #267 on: November 14, 2019, 18:43 »
Anyone tried using Moshou fiber HDMI with the Zappiti and AV amp?
My Moshou cables came and hooked up the Blu-ray player and ATV with no problems
However, Zappiti has blank screen
Update: Confirmed. Zappiti cannot use Moshou fiber HDMI cable
When I swop the Zappiti with my zidoo z9S using Moshou, it worked beautifully
« Last Edit: November 14, 2019, 23:10 by comfortablynumb »
« Reply #268 on: November 15, 2019, 06:39 »
Interesting discovery there...thanks for sharing here. Devil's advocate here - did you make sure the HDMI output like resolution, colorspace and bit-depth are the same for BOTH media players?
« Reply #269 on: November 15, 2019, 10:01 »
I will check the settings later but m quite sure they are similar
I will do more troubleshooting today
