Author Topic: Is Sony DAV C700 region-free?  (Read 4895 times)
Offline Zewt
« on: May 03, 2002, 11:32 »
Hi
Does anyone know whether Sony DAV-C700 sold in Singapore is region-free?
duckling
Re:Is Sony DAV C700 region-free?
« Reply #1 on: May 03, 2002, 11:37 »
I guess you need to modify this set - it's not region free by default like Pioneer players.
Offline Zewt
« Reply #2 on: May 03, 2002, 11:43 »
Hi
If i want to modify this set to region-free, how or where can i go to modify it?
duckling
« Reply #3 on: May 03, 2002, 13:23 »
Hi
You ask the shop that you're buying from... ;)
Offline Zewt
« Reply #4 on: May 03, 2002, 13:32 »
got a problem then cos i buy it straight from the main dealer(cheaper thats why) . which shop would you recommend if i want to modify it?
Offline porcu
  • Day in Day out, DVD!
« Reply #5 on: May 03, 2002, 13:37 »
Maybe can try SLS or People's Park?
Offline Zewt
« Reply #6 on: May 06, 2002, 11:45 »
Hi Guys
any shop in SLS to recommend to modify? how much will it cost?
btw did anyone modify this model before?
thanks.
Offline jeffong
  • You'll Never Walk Alone
« Reply #7 on: May 06, 2002, 13:30 »
U can try asking People's Audio located at People's Park Complex.  SLS wise, u can look for Alvin at Farle Enterprise located on the third floor (Facing the elevators).
HDR Rulez - Panny UB820 | Oppo UDP-203 | Zapitti One Mini | Apple TV 4K
Stewart Firehawk 92" | LG 65E6T | Panny 65VT30 | Benq 5700
Denon 8500 | Denon 7200WA | SVS PC-12+ | JL E110
Offline Zewt
« Reply #8 on: May 06, 2002, 13:53 »
ok guys. thanks for the info.
