Author Topic: Sony 4K players discussion thread: tips and info  (Read 53752 times)
Re: Sony 4K players discussion thread: tips and info
« Reply #375 on: April 14, 2019, 23:11 »
For all to take note that $279 offer @ Mustafa is over.
The price is backed to $319.
If u r looking for under $300 options, u r left with 2. The LG up970 that's currently under clearance @ courts, and the Xbox One S that's also going under clearance@ courts.
« Reply #376 on: April 20, 2019, 22:53 »
Just wondering what's the format for a USB drive? EXfat? How big can one use?
I've been having trouble and have only managed to use a 2Gb USB on it. It doesn't seem to recognise any other sizes or for that matter other USB sticks..
Offline Sach
« Reply #377 on: May 31, 2019, 12:56 »
Hi all
I have the X800M2 and it's a brilliant device. Sound quality is superb and same goes for the pic quality. User interface is rudimentary and it came with Netflix and YouTube 4k loaded.  I cannot load Amazon Prime Video as Sony won't allow me to register on Sony Essentials if outside US. Power supply is 120v, but it runs at 15w so a cheap converter works well.
Will need to reset the divice once running though VPN to get the benefit of 4K streams from the other providers.
Offline tigerman
« Reply #378 on: May 31, 2019, 20:45 »
the Sony x700 can't bitsteam out Atmos via the built in Netflix app in the player..
anyone having this problem?
I have set up settings according to the Sony x700 manual, but still can't get theatmos bitstream output via the Sony players Netflix app.
Online wcseow
« Reply #379 on: June 01, 2019, 01:36 »
I dont think x700 support Netflix atmos. Dont see that in the neflix atmos support device list
Offline tigerman
« Reply #380 on: June 01, 2019, 10:32 »
oh no....looks like I will have to sell away this player then.
thanks for the reply.
Online wcseow
« Reply #381 on: June 01, 2019, 11:13 »
This is what I could get from the Netflix site. Looks like the latest addition are the 2019 Panasonic and Toshiba tvs
Apple TV 4K (requires tvOS 12 or later)
LG OLED TVs (2017 or newer models)
Panasonic TVs (2019 or newer models)
Pixela 4K Smart Tuner
Sony BRAVIA Android TVs (2018 or newer models)
Toshiba TVs (2019 or newer models)
Vizio TVs (2018 or newer models)
Windows 10 computer or tablet (requires Windows 10 RS3 Build 16299 or later)
Xbox One, Xbox One S, and Xbox One X
Offline DizzyD
  • I am a HTphile !
« Reply #382 on: June 01, 2019, 13:54 »
For TV to support Netflix Atmos, I guess it must have eARC for both TV and AVR.
« Reply #383 on: June 01, 2019, 16:41 »
player embedded apps cannot deliver,TV embedded Netflix apps can or not?
Online wcseow
« Reply #384 on: June 01, 2019, 17:18 »
I think ARC can support lossy, eARC support lossless. Netflix app so far I believe is lossy or "perceptually transparent".
Not sure as I am using Xbox One X which "make every Netflix show to be Atmos" ..Lol
« Last Edit: June 01, 2019, 17:21 by wcseow »
Offline [D]ennis
« Reply #385 on: September 15, 2019, 14:43 »
can i check with u guys, jus got a sony X700 player, does it need the newer AVR to work? connect it to my old denon AVR 2310, couldnt get any images.. but if connect directly to TV, it works... ??? ???
« Reply #386 on: September 15, 2019, 15:40 »
2310 machiam not 4k compatible,if i not wrong...
Offline [D]ennis
« Reply #387 on: September 15, 2019, 16:01 »
confirm.. cos 7yrs ago no 4k yet.. haha
does that mean i need to change avr? bought a new player cos my PS3 died..
« Last Edit: September 15, 2019, 16:26 by [D]ennis »
« Reply #388 on: September 15, 2019, 16:36 »
The x700 comes with two HDMI ports
- one for audio - to your AVR
- one for video direct to your TV
OR...
Buy a new amp! It's time la... almost 10 years old... :)
Offline [D]ennis
« Reply #389 on: September 15, 2019, 23:00 »
OR...
Got it! Use until spoil then buy.. don waste money 🤭🤭
