Author Topic: Sony 4K players discussion thread: tips and info  (Read 57607 times)
Re: Sony 4K players discussion thread: tips and info
« Reply #15 on: November 20, 2017, 03:18 »
bros do check your HDMI cable. all my old HDMI cable cannot use. no display on my Panny 4k LED TV.
i forgot what version i bought maybe not 4K ready.
lucky the DynamicView Active High Speed HDMI Cable, 4K, HDR, 18Gbps, 24AWG, CL2, 50ft,
which i ordered came the next day. plug in. Display output OK.
« Last Edit: November 20, 2017, 03:26 by DJQ »
Dynaudio Confidence, Center, Contour SR, IC 17
Plinius CD101, Tautoro, SA103
Denon AVC X8500H, Sony BDP X700, Optoma UHD65
TAOC ASR II, ASR III
Offline Funkyjazz
« Reply #16 on: November 20, 2017, 08:35 »
I am using Audioquest HDMI cable which suppose to be 4K compatible.
Offline Gondon72
« Reply #17 on: November 20, 2017, 15:39 »
Try jor lor
Toh hai um tak.
Ho lan fan  ;D
Translate
Aldy tried.
Also cannot.
Fcuking frustrated
 ;D
like that how?  RMA back expensive?
Offline n3wk1d
  • I'm a newbies, be nice to me....
    • Alex Steelbook link
« Reply #18 on: November 20, 2017, 20:06 »
Got my x800 delivered today.
The player built is really good, solid and heavy. Not sure the weight is from where?
But I can't play 4k on my TV, it shows hdr>sd on info page.
If you are buying from Amazon, please help me by clicking from the link    AMAZON USA  |  AMAZON UK
Online petetherock
« Reply #19 on: November 20, 2017, 20:22 »
The chassis is solid bro. For vibration-resilience..
Did you manage to redeem the two free discs?
I thought the offer expired in Sept?
« Reply #20 on: November 20, 2017, 20:57 »
whole chassis top and bottom covered. chassis itself is the weight.
Offline n3wk1d
« Reply #21 on: November 20, 2017, 21:01 »
Haha, yeah man. A lot more better than the other players I have. The built totally doesn't look like entry level player.
This is my TV model Philips 65PFL9708 9000 Series, but player couldn't detect it's a 4k panel.
« Last Edit: November 20, 2017, 21:07 by n3wk1d »
« Reply #22 on: November 20, 2017, 21:07 »
the downside is the front panel not even any LCD/indicator display. just a simple power led. the newer 1000ES will have display.  ;)
Offline Chowbotak
  • Trade Count: (+7)
« Reply #23 on: November 20, 2017, 21:29 »
I think I ll open it up and shake the tray a little.  ;D
Online petetherock
« Reply #24 on: November 20, 2017, 21:37 »
For the money.. can't complain
Uses the basic same components, sans display, RCA out..
Offline CASH
  • Trade Count: (+29)
  • Cash-96660233, Pasir Ris St 21, Blk 236, S(510236)
    • My Hi-Fi and H/T Set Up
« Reply #25 on: November 20, 2017, 21:39 »
yup.. i would do that too.
jus use the small flat head screwdriver or a penknife to pull open the tray n manually pull n push many times.
I LIKE EM, MEATY, THICK AND ROUND!!!!
http://www.hraudio.net/library.php?user=11189
Online petetherock
« Reply #26 on: November 21, 2017, 21:39 »
Heavy, well made piece of gear..
Very fast, it will ask you for an update once you start up..
I wonder if it will allow you to access Netflix USA, has anyone tried?
Offline Gondon72
« Reply #27 on: November 21, 2017, 21:50 »
The player just arrived this evening, didn't expect it to reach so fast as i havent bought a stepdown voltage transformer.
May i know which brand are you all using?  I saw super star and super seven brand in SLT, not sure which is reliable.
Offline Ccyao
« Reply #28 on: November 21, 2017, 22:28 »
Bro,
Appreciate if you could share after you got the transformer. Looking for a relatively small and reliable one before I pull the trigger.
Thanks in advance!
Online petetherock
« Reply #29 on: November 21, 2017, 22:35 »
I have posted mine in the transformers thread..
Free shipping from USA too.
