Author Topic: Zidoo Media Players Only  (Read 123725 times)
Online dbchoong
  • .. Droid Rulez ..
Re: Zidoo Media Players Only
« Reply #885 on: May 22, 2020, 14:06 »
poki, did you try the "faulty" unit using WiFi? Maybe the ethernet connector on it might be bad.
Offline poki
« Reply #886 on: May 22, 2020, 14:25 »
tat I did not try, as my wifi connection is under a diff network, don't think it will be able to connect to the NAS
Offline Sunblock
« Reply #887 on: May 22, 2020, 18:16 »
Presume that both your units are having the same settings, .... suggest you try the following assuming that Player A (the faulty unit) and Player B (good unit) are connected via Cat 6 to the Lan switch to the NAS.
1) swop player A & player B and see if the problem moves with the unit. If yes, then player A is the culprit
2) if problem moves to player B then the problem lies iat the infrastructure layer (Cable or LAN Switch)
3) Leaving player B at the same location ... swop the lan cable to a different port at the lan switch and check eg port 3 to port 4
4) If problem still exists then most likely the lan cable is “faulty”.
5) if problem is solved then the previous lan port at the switch is defective.
Presume that you are using a gigabit switch with cat 6 wiring. Btw, is the lan switch managed or unmanaged and how many ports?
« Reply #888 on: May 22, 2020, 19:09 »
You can also try to connect the same movie via usb ext hdd. Do you still get the same issue? This will isolate if its a network issue.
Offline econav
« Reply #889 on: May 23, 2020, 15:43 »
Anyone want to try the New poster wall ver 3.0.35 wall on your Z9 ?
« Last Edit: May 23, 2020, 16:38 by econav »
All posts
Offline tertm141
« Reply #890 on: May 23, 2020, 16:22 »
New firmware released on Zidoo Telegram
Zidoo Mirror: https://bit.ly/3gdwfIw
Model: ZIDOO_Z9S
Version number: v2.3.30 (beta version)
MD5: A02DCB11549AC03EA88C2565952E84B5
Upgrade method: OTA
Changelog
(From here, translation via Google Translate.)
(original text below) / (оригинал ниже)
System
1. Fixed the issue that the local video played occasionally stuck
2. Optimize the smoothness of online video playback
Music
1. Fix the problem of no channel number display
2. Fix the problem of getting sampling rate error
3. Optimize folder scanning function
4. Optimize album logic
5. Optimize the front panel information display
6. CD playback adds song information
7. Optimization can not match online
Player
1. Fix the issue that the movie name is displayed wrongly
2. Add shortcut keys for subtitle download
3. Optimize the subtitle deletion function
4. Optimize the custom font function
5. After the location of the external SRT subtitle is set, the location of the built-in text subtitle will also change
6. Fix Swedish subtitles recognized as Swahili, Romanian is marked as Russian
File Manager
1. Increase SMB3.0 support
2. Add file filter switch
3. Fix the problem that the SACD files collected will be played in video mode
Poster Wall
1. Update to the new interface of Poster Wall 3.0
2. Optimize the title recognition, compatible with the "season x. Episode xx" video
3. When adding to the collection, the focus control of the collection list
4. Solve the problem of possible crash when scanning occasionally
5. Automatically categorized collection movies, adding "Remove Collection" function
6. Optimized movie added to the collection function
7. TV series category added to the left column of the home page
8. The movie details interface adds a trailer function (can be turned off in the settings)
9. Optimize the display of the new collection of personalized pictures
10. Solve the problem that the pictures of Douban matching movies are not clear
11. Optimize the function of getting local pictures automatically if the movie has no poster when the priority local picture switch is turned off
12. Rematch and add poster preview function
13. Solve the problem that the details of the video resolved through NFO will occasionally crash.
14. When the child lock password protection is closed, the main interface will no longer display the lock icon
15. Solve the problem that movies with the same title in different years will be matched into the same movie
16. Added CLEARLOGO function in the detail interface
17. Increase the function of Pop-up button of remote control
18. Solve the problem of "scanning" when adding devices
19. Solve the problem that the change of poster language does not take effect
20. Optimized sorting function
21. Priority search for TMDb during smart search
22. Optimize the child lock function
23. Search interface adds full keyboard input function
24. Add category browsing mode
25. Add custom widget function
26. Add custom classification function
27. Increase the viewing history of recently added forced time reverse display
28. Fix the problem that the widget external device does not display occasionally
29. The main interface widget adds region selection
30. Add custom function to the main interface type
31. Fix the problem that the main interface type is displayed in English individually
32. The main interface device adds a browsing mode (file and poster browsing)
33. It is recommended to add a display switch on the main interface
34. Recently added to increase the default sorting settings (add time and file time)
35. Add local trailer feature (movie name. Trailer.mp4)
36. Add alphabet navigation function on the poster list interface (effective when the poster names are sorted)
37. Optimize the trailer playback logic
38. Modify the default layout size of the poster list interface
39. Add the function of clearing application data
40. Optimize application stability
HDMI IN
1. Add PIP adjustable position and size function
DLNA
1. Fixed the issue that the playback ratio of individual videos is incorrect
Control Center
1. Add whether authorization confirmation switch is needed
2. Add mobile phone sleep interface
Hot Key
1. Add shortcut keys for subtitle download
Application Installer
1. Optimize web installation function
2. Support mobile phone installation
Mobile Phone Control
Android
1. Optimize connected device management
2. Add the function of installing local applications
ios
1. Add screenshot save phone function
2. Add the function of sharing APP files to the machine
Posted on @ZidooNews
https://t.me/ZidooNews
Оriginal text / Оригинал
型号:ZIDOO_Z9S
版本号:v2.3.30
升级方式:OTA
系統
1.修复播放本地视频偶现卡顿的问题
2.优化在线视频播放流畅性
音乐
1.修复没有声道数显示的问题
2.修复获取采样率出错的问题
3.优化文件夹扫描功能
4.优化专辑逻辑
5.优化前面板信息显示
6.CD播放增加歌曲信息
7.优化不能在线匹配的问题
播放器
1.修复影片名显示出错的问题
2.增加字幕下载快捷键
3.优化字幕删除功能
4.优化自定义字体功能
5.外挂SRT字幕设置了位置后,内置文本字幕位置也会跟着改动
6.修复瑞典语字幕识别成斯瓦西里语、罗马尼亚语被标记为俄语
文件管理器
1.增加SMB3.0的支持
2.增加文件筛选开关
3.修复收藏的SACD文件会以视频方式播放的问题
海报墙
1.更新到海报墙3.0全新界面
2.优化片名识别,兼容“第x季.第xx集”的视频
3.优化添加到合集时,合集列表的焦点控制
4.解决偶现扫描时有可能崩溃的问题
5.自动归类的合集影片,增加“移出合集”功能
6.优化影片添加到合集功能
7.首页左侧栏增加电视剧分类
8.影片详情界面增加预告片功能(可在设置中关闭)
9.优化新建合集同人化图片显示
10.解决豆瓣匹配的影片图片不清晰的问题
11.优化当关闭优先本地图片开关时,如果影片没有海报,会自动获取本地图片的功能
12.重新匹配增加海报预览功能
13.解决通过NFO解析的影片进入详情偶现会闪退的问题
14.儿童锁密码保护关闭时主界面将不再显示锁的图标
15.解决不同年份相同标题的电影会被匹配成同一部电影的问题
16.详情界面增加CLEARLOGO功能
17.增加遥控器Pop-up键功能
18.解决增加设备时,偶现一直显示“正在扫描”的问题
19.解决更改海报语言不生效的问题
20.优化排序功能
21.智能搜索时优先搜索TMDb
22.优化儿童锁功能
23.搜索界面增加全键盘输入功能
24.增分类浏览模式
25.增加自定义小组件功能
26.增加自定义分类功能
27.增加观看记录的最近添加强制时间倒序显示
28.修复小组件外接设备偶现不显示的问题
29.主界面小组件增加地区选择
30.主界面类型增加自定义功能
31.修复主界面类型个别显示为英文的问题
32.主界面设备增加浏览模式(文件和海报浏览)
33.主界面推荐增加显示开关
34.最近添加增加默认排序设置(添加时间与文件时间)
35.增加本地预告片功能(影片名.trailer.mp4)
36.海报列表界面增加字母导航功能(海报名排序时生效)
37.优化预告片播放逻辑
38.修改海报列表界面默认布局大小
39.增加清除应用数据功能
40.优化应用稳定性
HDMI IN
1.增加PIP可调节位置和大小功能
DLNA
1.修复个别影片播放比例不对的问题
控制中心
1.增加是否需要授权确认开关
2.增加手机休眠接口
快捷键
1.增加字幕下载快捷键
应用安装器
1.优化网页安装功能
2.支持手机安装
手机控制
安卓
1.优化连接设备管理
2.增加安装本地应用功能
ios
1.增加截图保存手机功能
2.增加分享APP文件安装到机器的功能
Offline rock123
  • Enjoy HT Fully! :)
« Reply #891 on: May 23, 2020, 17:08 »
thanks for this firmware!
« Last Edit: May 23, 2020, 17:16 by rock123 »
BenQ W2700 4K HDR   Source: Oppo UDP-203 & Zidoo Z9S
1996 Sunfire Cinema Grand l Denon AVR-X4400H Pre-out @7.4.4
M&K Sound LCR950 THX Select2 Series  miniDSP 2x4 HD
Sub 1 & 2: Dual Rythmik FV18s ea@900WRMS
Sub 3 & 4: Dual Sunfire True Subwoofer EQ Dual opposed 10"
Sub 5: Hsu Research MBM-12 MK2 (nearfield)
Offline econav
« Reply #892 on: May 23, 2020, 17:16 »
wow really got SACD there. thanks for this firmware!
For your eyes only.....
All posts
Online Earth Sound
  • ... by sound enthusiast
    • www.earthsound.com.sg
« Reply #893 on: May 23, 2020, 18:47 »
Some pictures on the new version ..
Sent from my SM-G975F using Tapatalk
| www.earthsound.com.sg | Facebook @ EarthSoundSG | Authorised dealer for StarkeSound, JVC, Ken Kreisel, Gallo Acoustic, Rythmik, Frank Acoustics ,Plixir.
Contact us @ 9092 1582
Lazada store @ https://www.lazada.sg/shop/earth-sound/
Offline wcseow
« Reply #894 on: May 24, 2020, 12:09 »
Hi
Like to check whether anyone able to play a mkv on the uhd2000 in 12 bit color depth?
I can't seem to. My setup is UHD2000 to AVC8500 connected to JVC N5. Have config the Zidoo display to 12 bit priority.
With the same mkv file, I can get 12 bit if I stream it on  Panasonic UB820 from the Zidoo. But when I used HT on Zidoo to play the same mkv file, it can do 10bit only.
Offline rock123
« Reply #895 on: May 24, 2020, 13:53 »
Hi
Think it will still show 10bit output even you set at 12 bit settings.
Can someone cfm? Thanks.
Offline wcseow
« Reply #896 on: May 24, 2020, 14:41 »
Oh. I forgot to mention that when mention it is 12 bit, I am checking on the video information received on the AVR and on the JVC N5.
When Zidoo is idle, the video information received on the AVR and JVC shows 10 bit.
Xbox One X is different. When I set it to Priority 12 bit, I get 12 bit when xbox is in home screen. Then it changes to 10 or 12 depending on which game or app I ran
« Reply #897 on: May 24, 2020, 15:30 »
yes therefore I was advised to set at 10 bit.
When I changed my resolution from 4k/60hz to 1080p/60hz... screen turned blank for few seconds then back to normal but Zidoo won't show tick sign
on your selection. It happened on my Z10.
How about your Z9S player bro?
Are we using the same FW ? also v2.3.30
« Last Edit: May 24, 2020, 15:32 by whitesox »
Offline rock123
« Reply #898 on: May 24, 2020, 16:30 »
My local set till on v2.2.97 bro.
Havent flashed yet.
Offline Sunblock
« Reply #899 on: May 24, 2020, 17:44 »
Setting to 12bit will not works because what we have today is only 10bit and not 12 bit color planar despite having hdmi 2.1 which supports 48Gbps bandwidth.
To take one step further, if your device is having 2.0 which the max bandwidth is 18Gbps then with HDR (10/12bit) will works in FHD at 100-120p using 4:4:4 (10-12bit) or 4:2:2 (8-12bit)
UHD settings with HDR
3840 x 2160 and 4096 x 2160 24-30p for 4:4:4 (10-12bit)  @18Gbps or 4:2:2 (10-12bit) @ 9Gbps
3840 x 2160 and 4096 x 2160 48-60p for 4:4:4 (8-12bit) or 4:2:2 (8-12bit) Or 4:2:0 (10-12bit) @ 18Gbps
3840 x 2160 and 4096 x 2160 100-120p for 4:4:4 (10bit) @ 40Gbps or 4:4:4 (12bit) @48Gbps or 4:2:2 (8-12bit) @32Gbps
In short, it depends whether the device supports hdmi version 2.0 or 2.1
Hope this info helps
« Last Edit: May 24, 2020, 18:34 by Sunblock »
