Author Topic: Zidoo Media Players Only  (Read 107154 times)
Offline chaozhoi
Re: Zidoo Media Players Only
« Reply #675 on: March 19, 2020, 22:14 »
Try copy the same file to a USB and plug direct to the USB to test and confirm the issue is the file or the network.
Thanks. I recently downgraded the firmware and seemed to have solve the problem!
Sent from my ONEPLUS A5000 using Tapatalk
Offline econav
« Reply #676 on: March 19, 2020, 22:26 »
Hi every one. Recently bought zidoo z9s fm aliexpress. I download movie fm rarbg. 2160 hevc. Copy to hdd external wd ultra.  Connect via usb to zidoo. Movie playback not smooth,always freeze few second or stuttering. Any solution ? Thz
few thing you can chk and test.
1) copy the same files to a USB drive and plug into the same USB port to play and if stable , then the info on yr Hdd is stutter all over after long use delete /copy and so on.
2) check the adaptor that come with your set and try with another 12V 3A adaptor , if stable , you know the issue....
3) Do a factory reset and don't install any apps first , just test play that files and see how.
All posts
Offline econav
« Reply #677 on: March 19, 2020, 22:32 »
Good to know , but better still do a factory direct reset then install the fresh firmware.
All posts
Offline econav
« Reply #678 on: March 26, 2020, 16:29 »
Roon ready under testing...
New poster wall with pre-view windows on it way ...
How abv having bluray ripping ....and concurrent 3 stream  from UHD2000....who know
« Last Edit: March 26, 2020, 16:46 by econav »
All posts
Online comfortablynumb
« Reply #679 on: March 26, 2020, 17:03 »
where to get latest fw ?
Offline econav
« Reply #680 on: March 26, 2020, 17:09 »
Only in my workshop for now , some have saw how it works .
All posts
Online wcseow
« Reply #681 on: March 26, 2020, 17:37 »
Lol..so i guess we will bring the unit down?
New firmware had cd ripping?..
I have done 2 per se, one on the uhd2000 and one on a xbox one. No issue.
Waiting for the other z10/z9s stock to be available..😀
Offline econav
« Reply #682 on: March 26, 2020, 21:54 »
now is only beta , remember i loaded something last week ...
All posts
Offline Gondon72
« Reply #683 on: March 26, 2020, 23:07 »
if  can do both ripping bluray and CDs...good dah..
Online wcseow
« Reply #684 on: March 27, 2020, 01:26 »
Lol...loaded something??.
Mine is 2.3.3, should be the latest international version.😁
Offline slooker02
« Reply #685 on: March 27, 2020, 07:45 »
hi all
where can I see, test and buy zidoo in Singapore?
Offline khlim_77
« Reply #686 on: March 27, 2020, 08:55 »
hi all
Tiday lazada have promotion ,
219 only
« Reply #687 on: March 27, 2020, 11:07 »
Actually what is the difference between international sets and Chinese ones (TB, Aliexpress...)?
Offline StephenBishop
« Reply #688 on: March 27, 2020, 13:31 »
I think for Z9 (which I bought from TB), the only differences are for the TB one 1) The remote has Chinese characters; and 2) The supplied plug is a China compatible plug (Type A).
Offline econav
« Reply #689 on: March 27, 2020, 13:39 »
1) China version the remote is Chinese wording.
2) Some model/version we hv IR with Bt remote.
3) China are locked OS , no goole , play store support and cant easy unlock to install, apps may not work outside china.
4) power supply or adaptor dif fron china
5) OEM/ODM board.
6) local support and warranty
7) some local dealer install their own service pack or pay service .
All posts
