Author Topic: Zidoo Media Players Only  (Read 123935 times)
Offline comfortablynumb
Re: Zidoo Media Players Only
« Reply #540 on: September 18, 2019, 21:46 »
Saw a X20 Pro unit available for sale this evening, HK$4,999.
I managed to resist.   :)
I bet you regret now  😂🤣😂
« Reply #541 on: September 23, 2019, 23:35 »
Model:ZIDOO_Z9S
Version:v2.2.96
Download here
Changelog:
System:
1.Fix the occasional green screen problem of HDMI IN
2.Optimize optical RAW output.
3. Optimize the stability of system.
4. Add German and Polish language support.
5. Fix the occasional noise problem when playing video.
6. Fix the problem that some online video applications couldn‘t be played.
7. Color depth output 10bit by default.
8. Optimize application stability.
9. Optimize online playback.
10. Fix the problem that the front panel USB icon was not displayed.
11. Optimize seamless branching issue.
12. Fix occasional prompts ”the format is not supported“ when playing dts music via HIFI MUSIC APP.
Music Player
1. Solve occasional error message of playing the music through the file manager.
2. Lyrics closing function is added.
3. Add German and Polish language support.
4. Optimize stability of application.
5. Optimize the function of obtaining music information.
6. Optimize the problem of automatically switching the next track.
7. Fix the stuck problem of 64bit music players.
8. Optimize the music basic information interface.
9. Add album folder recognition function.
10. Solve the abnormal songs display problem in flac album folder.
11. Optimize the image recognition and profile text recognition of album folders.(need to clean the old data and rescan)
12. Fix the problem that some CUE songs are not successfully matched.
13. Optimize recognition error caused by suffix identifier of the folder.
14. Add scroll bar for list.
Control center
1. Add the function of uploading screen shots from mobile phone.
2. Optimize stability of connection .
3. QR code for downloading IOS and Android app.
Poster wall
1. Solve crash issue during the matching process.
2. Solve the problem of recognizing ISO music as ISO video.
3. Improve the recognition rate of files with parentheses in file names.
4. Compatible with title of file name with ”·“.
5. Optiнедопустимая ссылкаocal image recognition.
6. Fix inaccurate automatic update due to the incorrect judgment of the video file.
7. Solve the problem that the restore function of mobile phone control app does not work.
8. Add function to view folder directly in device list.
9. Add device synchronization function.
10. Solve jitter issue caused by long device name when scanning device.
11. Solve abnormal folder size display on folder viewing interface.
12. Solve losing focus problem after stop scanning in the device list interface.
13. Fix the issue that BD cannot be deleted.
14. Solve the problem that non-Chinese and non-English titles could not be matched.
15. Fix the problem that the poster modification from web page cannot select image on the computer.
16. Category browsing by movies/TV series.
17. Optimize accented characters incorrect sort issue.
18. Optimize the initialization speed of the sorting tool.
19. Solve the occasional crash problem on category browsing.
20. Turn on PIP by default.
Local player
1. Add Blu-ray forced subtitle.
2. Press the delete button on remote control to delete plug-in subtitle.
3. Add more information interface for app control.
4. Optimize the progress bar.
5. Optimize play button no response problem after popping up menus.
6. When switching to 3D mode, associated frame rate will pause time.
7. Fix the problem that bit rate 1b/s show up coincidentally.
8. Optimize some shortcut keys.
9. Fix the problem that the download subtitle from mobile phone is different form media player.
10. Add Playlist on Mobile phone App.
11. Add more information of video display on Mobile phone app.
Weather
1. Resolve some wrong data display issue.
Quick settings
1. Add function that forced subtitles follow the language of audio track.
2. Fix the problem of incomplete German display.
One-click cleaning
1. Add Polish language support.
2. Fix the abnormal focus problem in the APK file management user interface.
Unfortunately, it did not really resolve the 4K UHD lock-up issues.
« Last Edit: September 23, 2019, 23:36 by desray »
Offline kaydee6
« Reply #542 on: September 25, 2019, 07:06 »
@Desray,
You experience 4K lock up issues with both the .91 and .96 firmware? Happens to both ISO and mkv?
« Reply #543 on: September 25, 2019, 07:09 »
@Desray,
Yes. I also experience intermittent lock-ups on 4K mkv files. But I only tested 1 title so far.
« Reply #544 on: September 28, 2019, 14:24 »
For those who wants a X20Pro/Z1000 home user interface (for the black and sleek looks) as opposed to that Android TV box like UI. You can install this apk file which I retrieved from the app folder of Z1000 firmware. Just go to APKInstaller or Media Center to select the apk and hit install. If asked for default launcher skin, just select the new Z1000 and select as default. Take note that it doesn't change the functionality or the UI of Settings etc...just the home page. Furthermore, all those customization like replacement of apps on the home menu can no longer be performed. So it is more of a "cosmetic change" than anything else.
Change from looking like this:
to like this:
« Last Edit: September 28, 2019, 20:24 by desray »
Offline sigurros
  • "What we think, we become"
« Reply #545 on: September 28, 2019, 20:22 »
Link working now.
Thanks.
« Last Edit: September 28, 2019, 21:26 by sigurros »
« Reply #546 on: September 28, 2019, 20:24 »
Offline Chowbotak
  • Trade Count: (+7)
« Reply #547 on: September 28, 2019, 22:56 »
I ordered an X10. It has a bay for int hdd. Would PQ would be better if I play files from the hdd instead of wireless from my NAS (in a different room) ?
Offline Wilber
  • Trade Count: (+7)
« Reply #548 on: September 28, 2019, 23:27 »
no. just prevention of stuttering/buffering.
unless you do use app like plex.. it has automatic adjustment to the picture quality according to the speed/bandwidth to ensure smooth playback but that of course can be overridden with original quality, stuttering/buffering may occur.
« Last Edit: September 29, 2019, 09:48 by Wilber »
HT Setup
Marantz AV8802A, JBL Professional Speakers Powered by Harman Crown DCI amps. Zidoo X9S. Clef Cleansource Power Regenerators, Optoma UHD65, Panamorph Lens With Powered Sled, Prismasonic Curve Frame with UF Fabric, Fibaro Home Automation.
Computer Setup
KEF Reference 1 Powered by Harman Crown DCI amp, Topping D90 (AK4499)
Offline Chowbotak
  • Trade Count: (+7)
« Reply #549 on: September 29, 2019, 03:09 »
Thanks bro!
« Reply #550 on: September 29, 2019, 10:42 »
Downgrading from firmware 2.2.96 to 2.2.82
I understand that the recent firmware release (2.2.96) did more "harm" than good especially for 4K content. The previous firmware version 2.2.82 appeared to be more "stable" when it comes to 4K video playback. There is a way to revert to 2.2.82 but requires a flash boot using the "stock" (base) firmware released back in 2018. I have the said firmware in (.img) to allow bootloading using the flash boot.
I'm not sure how many faced this 4K playback issue and wished to revert to the previous version of 2.2.82. If there is a demand for it then I will list down the steps to perform the downgrade yourself and then upgrade to version 2.2.82, otherwise I will not waste my time.
The most annoying bugs for me in the more recent Zidoo firmware for Z9S (that include 2.2.82) include:
(-) Random disconnection from USB 3.0/ HDD Docking station every 1hr - 1.5hrs into a movie - content and type of media files are irrelevant as long as it plays from a USB 3.0 external drive/external HDD docking station
(-) Seamless branching for some BD ISO/BDMV file structure still not fixed
« Last Edit: September 29, 2019, 13:19 by desray »
« Reply #551 on: October 13, 2019, 21:03 »
I wasn’t able to run live channel 5/8 from toggle app on z9s. Anyone manage to resolve this? Loading the app is fine. Issue happens when I click on channel 8 icon, all I see is a black screen. Seems like a display compatibility configuration issue.
« Reply #552 on: October 14, 2019, 17:47 »
I never even bother to use the feature :P
Maybe bro Wilbur can chip in?
Offline Sunblock
« Reply #553 on: October 14, 2019, 18:32 »
Can't play any "live" channels ie 5,8,CNA, etc but has no problems playing other "pre-recorded" contents.
« Reply #554 on: October 14, 2019, 18:35 »
Yes :(
Sent from my SM-G975F using Tapatalk
