Author Topic: New project alert! 3 Generations  (Read 16930 times)
Offline ericsec
Re: New project alert! 3 Generations
« Reply #30 on: December 27, 2017, 18:13 »
I know nothing about electronic and your diy amps looks dam cool. really envy and enjoy those pictures.
keep up the great works and more picture pls
 ;D
Offline ed
  • Kill 'em all, let g*d sort 'em out...
« Reply #31 on: January 04, 2018, 16:28 »
Keep at it....part of the enjoyment of the journey :P
Yup.  This one is a tough nut.  Switch to DC heaters hum is there.  Swopped input jacks to a shorter path still same.  Shifted some grounding still no help.  Well I guess got to redo the whole thing again.  Not the first time, but always hope that its the last time.  Hahaha...
jlow
Offline ed
« Reply #32 on: January 04, 2018, 16:34 »
 ;D
I am glad you liked it.  The problem with me is that I had too many parts at home and have always kept myself occupied with a few solders a night.  Rather therapeutic I would say.  Not really making $$$ out of it.  Occasional sales to fund other projects.  Keep the hobby and interest going.  Pass the time that I need to pass.
« Last Edit: January 05, 2018, 08:46 by ed »
Offline ed
« Reply #33 on: January 04, 2018, 16:59 »
If you have seen this video below:
https://www.youtube.com/watch?v=ewD6C6kKaAY
You would have noticed that there is a rocking sound when the turntable starts to play.  Well I have decided to give it another try to fix this problem.  Unscrewed the plate holding the center post spindle or stub spindle of the TT and realized that it has 4 coils which are magnetized when powered.  The magnetic force then repels the magnet on the platter and causes it to go airborne while spinning.  Brilliant piece of work.  Out of the 4 coils 2 of them which are suppose to be glued to the surface got loose.  My guess is that the so called glue that holds them has worn off over the years.  What I did is reapply a thin layer of varnish and stick the coils back to position and leave them to dry.  After drying did a test and everything sounded perfect, without the rocking sound of course.
Messy job and didn't manage to take pics of this repair.  But have uploaded another video of the TT playing without any undesired sound and the link is below.  That's is the best start of 2018 for me.
https://www.youtube.com/watch?v=RM59j_vEmsE
jlow
« Last Edit: January 05, 2018, 14:01 by ed »
Offline ed
« Reply #34 on: January 04, 2018, 22:55 »
Done some drilling and polishing tonight.  Hope fellow DIYers can still recognize this tonearm.
jlow
« Last Edit: January 05, 2018, 08:50 by ed »
Offline DIYer Straits
  • 6N6P Über Tube
« Reply #35 on: January 06, 2018, 00:21 »
Nice attempt at a Technoarm but they have more holes, and bigger ones too.  ;D
Laptop via XMOS
Khadas Tone DAC
Custom 6N5P/6N6p Aikido Preamplifier
Modded TPA3118 Class D amplifier/Modded TPA 3255 power amplifier/Anaview AMS1000 power amplifier/KT88 SE
FAST with a 6.5" Satori mid and a 12" Pro woofer/Some Satori in birch ply cabinets with a PR/KEF R300
To be updated
Online BTW
« Reply #36 on: January 06, 2018, 08:23 »
No need to be the same lah.... ;) Good job by Bro Ed.....  ;D
Offline ed
« Reply #37 on: January 08, 2018, 09:18 »
The p
The problem is some of the parts are plastic and cannot be polished.  I wonder if a mix of black and silvery aluminium will look cool or weird...    ??? ???
« Last Edit: January 08, 2018, 09:20 by ed »
  • 6N6P Über Tube
« Reply #38 on: January 08, 2018, 09:59 »
The p
Just use Damar varnish if you don't have C37 lacquer.
Sent from my MI MAX 2 using Tapatalk
Laptop via XMOS
Khadas Tone DAC
To be updated
Offline ed
« Reply #39 on: January 09, 2018, 09:16 »
Ok lets hope I get that finish which I am looking for, thank DIYer
« Reply #40 on: March 26, 2018, 20:34 »
Bro there is a good reason Pete uses 5mm SS for his plates...anything less won't be ideal - I have one and built 2 TT's based on this plate for a friend...One of which he passed to me.
Good luck with your build tho. Drilling SS is not hard but you need good new drill bits. PTP's plates come pre drilled so easy to do :P
Do yourself a favour and buy a decent set of SS digital callipers too. You wont regret...use mine all the time.
« Last Edit: March 26, 2018, 20:36 by wizardofoz »
Offline ed
« Reply #41 on: March 27, 2018, 10:07 »
Pete used 4mm SS actually.  Anyway I am trying the PTP clone because I have some loose parts that are good enough for a new turntable.  Very much experimental and it is unlikely that I will follow exactly what he does.  There must be hundreds of permutations out there for the PTP ranging from plinth, setup, tonearm and cartridge.  I am just whipping up something that I felt is doable, not to challenge those who have spent big $ on the real thing.  Neither am I a conformist in my DIY pursuits.
Not touching SS for now, I have plans to reuse the SS plate for other projects.  I do have the carbide bits but I am already half way through with the aluminum plates.  I do have a B&D saw but prefer to do it this way in my little work space with minimum noise to my neighbours.  They have been nice to me so far.
Ditch the Analog caliper for Digital?  That question that has been ringing in my mind all the time.  Will seriously consider that if I have more projects coming but I really don't think so.  My plan is to stop DIY after all my projects are completed.  That is provided I can finish them.
The next few days will be mostly drilling and filing for me...
jlow
« Last Edit: April 02, 2018, 09:02 by ed »
Offline ed
« Reply #42 on: March 30, 2018, 22:20 »
Part 1 of 2 almost there.  Just need some touch up filing and sanding.  Hope to get the second part started soon.  Very time consuming work here.
Sent from my Redmi Note 4 using Tapatalk
Offline ed
« Reply #43 on: April 01, 2018, 10:39 »
Part 2 almost there too
Tough work!
« Last Edit: April 01, 2018, 10:56 by ed »
« Reply #44 on: April 02, 2018, 14:13 »
Sorry my typo yes 4mm here is a pic
and underneath the platter
« Last Edit: April 02, 2018, 14:15 by wizardofoz »
