Author Topic: Recommendations for vfm digital TV box  (Read 5925 times)
Offline pcking
Re: Recommendations for vfm digital TV box
« Reply #15 on: July 16, 2017, 10:24 »
Bro, if your TV do not have the hardware itself, which is the DVBT2 tuner, how do expect it to decode the signals ?
An antenna only enables the receiving of the signals. Not decoding it.
Not sure what TV r U using now but if your TV does not have built in DVBT2, I presume your TV's age should be at least 3 or more years old ?
If that's the case, time to upgrade if you r an AV buff.
Unless this is just a secondary TV.
Mine arrived. Not bad for $25. But wife doesn't like the additional TV box.
If I use the 3m $25 one in the below link, can it work on its own without dtv box? my TV which do not have dtv built in
http://newmediasolutions.azurewebsites.net/Home/Store
« Reply #16 on: July 16, 2017, 14:42 »
Nope, no TVBT2 tuner inside. Using a Samsung plasma.
Which brand has a better user GUI? Think need to change mine, don't like the GUI for the one i just bought.
« Last Edit: July 16, 2017, 15:08 by sevenz »
« Reply #17 on: August 18, 2017, 11:23 »
thanks all! zoomed into this one in the end:
http://list.qoo10.sg/item/NEW-CHIPSET-SUPPORT-RECORD-AND-TIMER-RECORD-SINGAPORE-HD-DVB/466002984
Feedback about the quality of this item. Used for 1 month and video card went cranky already.
GUI also not good. Won't encourage anyone to buy.
Looking for a better quality one.
Should I try NewMedia Solutions or AC Ryan?
« Reply #18 on: June 20, 2018, 17:45 »
Need to check with fellow bros here...
Those whom are using DVBT2 settop box connecting to their "still strong" old TV ones... Which model in the market now supports Programmable Video Recording via RCA connection outputs huh?
Majority seems to be only record thru USB thumb drive connections only?
Offline alf
    • www.entheos.com.sg
« Reply #20 on: November 12, 2018, 21:57 »
Can get free set from INFOMM MEDIA DEVELOPMENT AUTHORITY, the free set is for HDB owners only and  cannot be under subscription of Star Hub or Singtel .
« Reply #21 on: November 12, 2018, 22:08 »
Free as if...?
With the IMDA redemption letter? Boh Hua Lah!!!
Get discounts for TV with the digital tuner better. Warranty for 3yrs!
