Author Topic: Recommendation for speaker needed  (Read 30522 times)
Offline ongus
Re:Recommendation for speaker needed
« Reply #45 on: May 02, 2002, 07:39 »
Known at least a few Harbeth users who use Bryston amps with very satisfactory result.
But earlier you said all solid state power amps sound the same ....so how will Brystons be different from, say, Quad which the factory uses to voice their spks?
Offline hw
« Reply #46 on: May 02, 2002, 10:08 »
It is definitely possible. All you need is the right TOOLS.
